Timing Help Needed
Epps1983
Clarksville, TN
Just received a timing light and vacuum gauge, plugged everything off and hooked up to full manifold and was getting a steady reading of about 13 1/2 to 14. I knew that was kind of low but not knowing what engine work was done at the time of rebuild I went ahead.
Hooked the timing light up and she was set at 10 deg ATDC, loosened the dist and set it at 10 deg BTDC where the builder had a chalk mark. (Vacuum adv is still disconnected). After making the timing adjustment my vacuum increased to a steady reading of about 17, after adjusting the mix screws I brought it up to 18. I lowered the curb idle back down to 650 RPM's and checked my total advance at 3000 RPM's and found it to be 30 degrees. Is that enough?????
Also once I hooked the advance back up to the ported source the timing at idle stayed at 10 deg BTDC, shouldnt it be more advanced than that with vaccum attached? Also at about 2000 RPM the timing advanced to around 40 degs.
Can someone help me out here and help me make sense of this
Cheers,
Shawn
B RON CO
Statesville, NC
Hi, it sounds like you are doing very well with your new equipment.
Now you know your mechanical and vacuum advance works.
The vacuum advance is set up on ported vacuum and does not come on until the throttle is opened. You can check that hose with the vacuum gauge.
10 degrees at idle is not too much advance. You can advance the timing a little more, as long as it doesn't ping under load.
I bet it runs a whole lot better.
Good luck
gr8scott
The ported vacuum source has no vacuum at idle. It comes in off-idle (throttle open). The vacuum advance added 10* to
your total. You should be all good. Take it for a drive yet? How'd she run?
Edit: B RON CO beat me to it!
Jebus
Longview, WA
If I am reading this and the other thread correctly it sounds about right.
Be good to know if there is a lot of overlap on the valve timing.
Base at 10 degrees.
Max centrifugal advance at 30 degrees.
Vacuum carrying it forward from there depending on load for mileage.
The RPM points of these two advance mechanisms and total advance will depend on your engine and other gearing variables so it does not advance too fast and ping when warm under load. It's a long stroke motor so you have oodles of torque.
The ported vacuum has no vacuum when throttle plates are closed by design. Vacuum advance is not needed at idle.
How does it drive warm, with those timings?
broncnaz
You could probably run 12-14 degrees initial timing. Everything else sounds good. don't worry much about what your getting with vacuum hooked up as was said its load dependent and reacts different when actually driving. Basic rule is to run as much timing as you can as long as the engine is not pinging your fine.
Every engine is different so you probably should play around with a few settings see if there is any more improvements to be made.
Epps1983
Epps1983
Clarksville, TN
Guys it ran pretty well and I noticed a lot more response from the engine but I expected that seeing as how far off the initial timing was. I might try advancing it a little more this weekend when I get the time, Ive just had issues with it dieseling in the past. I'm not sure that Ive heard an engine ping before but I'm assuming it is pretty obvious when it happens? If it's going to ping should I expect it in a certain RPM range?
Thanks,
Shawn
B RON CO
Statesville, NC
Hi, if you have too much advance it will ping going uphill in 2nd gear. That is how I tell. Most guys like more advance then factory specs call for.
Very excess advanced timing and the starter may have trouble cranking the engine.
Generally dieseling and running on is because the idle is too high.
Good luck
