as far as the distributor rotor, i can move it so i know the mech advance is working but how easy or hard should it be to move it?
Quite easy. But you should feel some spring pressure almost immediately and it should spring back all the way when you release it.
For actual turning resistance, it's very little. No real resistance of note, other than the spring pressure.
is it possible with good compression, numbers above, that the valves could still be over tightened?
Pretty unlikely. If they're over-tightened to the point of holding a valve open, your compression pretty much disappears. Might still have some, depending on how much the valve is open, but it would bleed off almost immediately after the piston gets past the top.
i have a dial indicator that i can try to measure the lift on each cylinder to see if any are off showing it could be worn down. but if some lifters are drained out then i would get bad readings.
Yes they would give inconsistent readings. But how long since it ran? Even if it does not fully run, but you crank the starter for a few moments and see oil pressure build on the gauge, that should be enough to get you some pretty good readings.
Maybe not perfect, but pretty darn good.
For reading the gauge, it won't read until you release the key. So when you think you have some pressure, let off the key from START to the RUN/ON position and then the gauges get power and you should see residual pressure on the oil gauge. At that point then every time you crank it after that the pressure is there and should be sufficient to pump up the lifters.
