Ok here's another one. I been reading if you run a GM type or HEI on a Ford that you should run full vacuum advance because that's the way GM designed it, but if it's a Ford type design that timed (ported) vacuum is the way to go. I guesting that it's all in the design of the vacuum advance canister?
I'd say it still depends on the whole setup. How is the timing curve designed in the distributor? Even though it's based off of of the GM/HEI design, is the curve generic, or is each one tweaked for the intended application?
And not all GM vacuum advance specifications called for manifold vacuum if I'm not mistaken. Because of that, and the fact that you're still running it on a Ford, and that your Ford is not even stock any more (most likely anyway), you probably still have experiment for your best performance.
Try it both way to see what makes you happy. Your results may vary...
I think to take advantage of all the timing options (mechanical and vacuum) you need to run premium fuel with 8to1 compression. Back in the day 1969 or so regular fuel was 91-92 & premium at 100-102 and low compression was 9to1 plus, and it was real gas.
You're right about the octane and (mostly) compression ratios, but your basic Broncos did not come with the higher compression setups even for their time. And with wedge-shaped combustion chambers, most years EB's were pretty forgiving of detonation/pre-ignition/pinging.
If I remember the peak for a Bronco V8 was in '66 and '67, would have only been about 9.3 to 1 ratios. It was all down hill after that. Mine probably has about 8.5 to 1, while the mid to later seventies EB's were nearer 8.0 to 1.
Fairly forgiving, even on today's gas (here in CA anyway, not sure about elsewhere) and any engine can benefit from fine-tuning the advance curve to best take advantage of all of the fuel during combustion under different circumstances.
So tweak away. Experiment with timing (static, mechanical and vacuum) until you're blue in the face. Listen to what works and what doesn't with those that have modified their curves.
Even a low compression engine on today's regular grade fuels can utilize vacuum advance to good effect. The OE's ran vacuum advance distributors on engines all the way into the nineties.
Lots of members here using the DUI and it's clones to good effect. My personal favorites though are the new Mallory electronic distributors Max-Fire and E-Fire (like this
http://mallory-ignition.com/max-fire-distributor-ford-w-comp-9000.html) with electronic advance.
You set the curve with a dial, or custom tune your own with the included software on your home computer or laptop. Self contained and multiple sparks in one of them too. The vacuum advance is a modern MAP sensor instead of a mechanical dashpot. Very cool stuff.
I'm really interested in this distributorless setup too now though.
http://www.compu-tronix.com/DIS8.htm
Great idea that.
Have fun deciding and experimenting!
