Torque Steer? Possible causes/solutions?
yewhi
San Diego
Hi All,
I'm just trying to educate myself and in the process case down a few gremlins in my Bronco. My Bronco was a 73 with a 77 front end including y linkage. I just upgraded the following...
-2.5 inch WH lift with Bilsteins
-adjustable trac bar (for a 73')
-1" Body lift
-WH Y to T steering linkage kit
-Rebuilt the steering box
-Selectable lockers (Front Yukon Zip, Rear ARB)
-4.11's
-35 Spline Axles (WH) in the original small bearing 9"
-33" BFG's Up from 31's
The right tie rod end is currently rubbing on the rim when you turn hard to the left. and I'll install a set of 1.25" spacers on the front this weekend.
Everything was aligned and the front axle centered.
Long story short, I get it back and it pulls hard to the right on acceleration. Let off the gas and it pulls back to the left. Scary as h*ll to drive as you end up in places you never intended to go. I'm just curious whether anybody has run into this issue and how you solved it?
The mechanic that did the installation thought it was a rear end issue while the gear shop insisted it had something to do with the Trac bar's mounting location. I have an appointment to take it to another alignment shop this weekend that supposedly has more experience with this problem but I'm afraid I'm a bit clueless on this one.
Any suggestions would be much appreciated.
Thanks!
Tim
Toddpole
Sounds like your track bar and drag link are not parallel and/or not in the same plane. Post a picture of your front axle (tire to tire) down low so we can see the linkages.
clarrance
Sounds like your trac bar is not parallel with your drag link. Post a picture of your front end. If your using a drop pitman arm or drop trac bar mount, that's probably the problem, only having a 2.5" lift.
yewhi
yewhi
San Diego
Thanks gentlemen! I'll post a picture when I get home. I'm not using either a drop pitman arm or a drop trac bar mount but never-the-less I'll post a good image and let you all be the judge.
Thanks!
TCN
Whoaa
Hi All,
^...this issue is unique to 76/77 model Dana 44 disk brake front ends. They have slightly different knuckles and requires a little more clearance in the form of wheel back spacing. Generally speaking 3 1/2" of back spacing works nicely for this front end. Of course wheels come in many different sizes and style, a lot of modern wheels have 4" or 4 1/2" of back spacing and this causes issues w/ the 76/77 front end.
The spacers are a good option for now, however sometime in the future when you buy new wheels get the correct back spacing.
And as others have said, you're trying to make the trac bar and drag link the most parallel to each others as you can. You have a few options to choose from, and once we see pic's of your front end we'll know exactly whats going on.
One option to help is to move the tie rod to the top of the knuckles, this moves the tie rod up a couple of inches, which lessen's the angle of the drag link , which can make enough difference to make them parallel...but again we need to see pic's.
Here's a pic of the TRO conversion on a 76/77 style front end, and these wheels have 3 1/2" of backspacing and allow for plenty of clearance
Your WH conversion from 76/77', Y to T should look a lot like this, with the exception of the trac bar riser welded to the front housing to accomodate 5 1/2" of suspension lift
And here's another pic showing how much room you have w/ 3 1/2" back spacing wheels, plus the TRO. These are 17" wheels and fit nicely. And moving the tie rod to the top of the knuckles is easy. You can buy the correct size reamer from WH, chuck it into your Dewalt drill , ream for 5 minutes and then re-install.....easy-smeazy
yewhi
yewhi
San Diego
Thanks all! This helps greatly. My apologies for the crappy cell phone pic. I removed the steering stabilizer but the bracket is still in place to help see the Draglink/trac bar better. Honestly, it doesn't appear to be terrible based on the images Whoaa above but tell me what you all think.
Remember this is still really fresh. I just checked the tire pressure and it is what I consider to be on the high side (~45 PSI). That could be contributing. I'll try dropping it into the 32-34 PSI range tonight and see if it makes a difference.
Thanks again for all of the advice! It has been very helpful.
TCN
Apogee
Tangent, OR
...I just checked the tire pressure and it is what I consider to be on the high side (~45 PSI). That could be contributing. I'll try dropping it into the 32-34 PSI range tonight and see if it makes a difference.
Holy #@%&...45 psi is crazy high. I've been running my 33x12.5's at about 28-30 with the best results, but even a few psi one way or the other can make a major difference. Your steering geometry looks pretty good IMO all things considered.
SHX669
On the tire pressure ; I run between 26-30# - occasionally 24.
Have you checked to see if your ARB is disconnecting? The symptoms you describe mirror the issues we used to have with the Old School (1970s) Detroit Lockers.
yewhi
yewhi
San Diego
Thanks! I haven't checked. What would be the best way? Engage the locker, drive a short distance then disengage? This is my first experience with a locker but I'm assuming that it's behavior on pavement will be significantly different engaged vs disengaged.
It would be nice if the tire pressure were the sole issue but I'm guessing it is just exaggerating another problem. The question in my mind is how major/minor that other issue is? I aired down the tires this morning but didn't have a chance to take it out ? I'll get a chance to do that this evening and I can double check the status of the locker at the same time.
Thanks again!
garberz
Bronco Influencer
Conejo Valley, Ca.
Put a jack under the rear end, get the tires off the ground, and see if the tire rotate independently of each other, or if they're locked together like a spool. Dropping your tire pressure down to 26-28PSI will make for a much nicer ride down the road.
Mark
roundhouse
Sounds like the rear axle U bolts are not tight
Or the mounting pads on the axle are worn
Mine did just what you're describing and it turns out the pads on the axle were worn on the front and back , you could see it when you put a straightedge on the pad where the springs lay
Also the holes for the locating pin were egg shaped allowing the axle to move just a tiny bit
yewhi
yewhi
San Diego
Mark
Easy enough. Thanks!
it's funny how the angle the pictures are taken can skew the visuals, but your linkage angles sure look steep for just a 2.5" lift. At least from here and that small pic.
Wouldn't hurt perhaps to verify you actually got 2.5" of lift by measuring between the bottom of the frame and the top of the axle tube. If you're between 9 and 10 inches, you're in the money.
Which may mean you're one of the lucky ones that can use a dropped pitman arm and trackbar bracket even with the low lift. Lots of folks don't and drive just fine, while many others need the drops.
Definitely check out what all the others have said first though, before deciding to throw any more parts at it just yet.
And along those lines... I can't tell for sure from the image, but if your draglink's lower zerk/grease fitting is pointing straight ahead, that will be at least part of your issue. You want it pointed upward at roughly a 45° angle. This usually accomplishes two things. It lowers the overall angle, and helps make the two bars more parallel.
Simple enough to fix.
So:
1. Definitely lower tire pressures. Jump all the way down to 30 for a beginning, and see what it likes from there. Whether up or down.
2. Make sure the rear u-bolts are tight (and re-torque after a few hundred miles).
3. Verify the angle on the draglink's lower rod end.
4. Make sure that your lockers are not locked. Probably not, but you can't just assume anything at this point.
5. If all that does not work, my Plan-B would be to drop the steering angles more to make them more parallel to the ground. Torque/bump steer is a classic steep angle issue.
Good luck.
yewhi
yewhi
San Diego
So:
Good luck.
As always, That's again Paul!
I measured the frame to Axle housing distance and it is spot on 9.5 inches so it would appear that I have the correct lift.
I also took a look at the lower joint for the draglink and it is actually pointed downward at about a 15 degree angle. Images below.
I didn't do the install so I'm going to ask a stupid question (but it'll save me from making a mistake down the road). In order to loosen the tie rod I would simply loosen the left and right brackets, move the tie rod into position and then snug up the brackets. Correct?
It appears that moving the tie rod such that it is at a 45 degree angle will move the lower mounting point up roughly 0.5 inches. I'm assuming that the 1/3 turn of the tie rod probably won't change the position of the tie rod significantly to warrant another alignment?
Thanks again for the feedback! You all are a huge help!
Tim
PS. I adjusted the tire pressure yesterday and took her for a quick drive. There was a mild improvement but the underlying issue is still evident. I haven't had the chance to check the rear end or the lockers yet.
WILDHORSES
USA
I think a drop pitman would solve 90% of this problem. I'll even give you the $ back guarantee. If it does not work I'll pay to bring the pitman back. Seriously.;D Sorry I did not read every post word for word maybe this was covered.
Jim
yewhi
yewhi
San Diego
Jim
Thanks Jim!
I'm willing to give this a shot. I do have a question though. This is a 73 with a 76/77 front end. Given this used the Y to T conversion kit I'm assuming the Drop pitman arm I'd need would be for a 76/77, Correct? The other question is because I'm dropping the pitman arm do I also need to install a drop bracket for the trac bar? If so given it is a 73' the correct bracket would be the 66-75 bracket, right?
Thanks again!
Tim N.
EDIT: never mind. I called WH, spoke with Matt and he got me all squared away. Paul and Jim (and everyone else for that matter)- Thank you again for everything!
PaveBronco
it was mentioned before, did you check the torque on the rear U bolts? I had some Q steer and found the rear needed re-torqueing. the other part of my problem was one of the radius arm to frame bushings was falling apart, allowing some front to back movement. but I also noticed that under braking.
blubuckaroo
Grease Monkey
Ridgefield WA
I did the same "Y to T" swap on my 2.5" lift, and WH recommended the dropped pitman arm at the time of purchase. I'm a bit surprised they didn't mention it till now.
Actually mine would have benefited from the dropped pitman arm even with the "Y" steering. Bump steer became a problem when I replaced the auto tranny with a manual. It would pull the steering when the nose dropped during gear shifts. With one hand on the shifter and one on the wheel, it was a real problem.
yewhi
yewhi
San Diego
It's not their fault. I had dropped the Bronco off with my mechanic on A Saturday to get the steering box rebuilt, got to talking and decided that the Y to T swap was a good thing to do at the same time. So to save time, I ordered it online the same day and had it delivered directly to him. Honestly, these guys are awesome. Had I actually spoken with them there's a good chance I wouldn't be typing right now. :)
...This is a 73 with a 76/77 front end. Given this used the Y to T conversion kit I'm assuming the Drop pitman arm I'd need would be for a 76/77, Correct?
Sounds like you already have it figured out from your edit below, but I'll talk through the process here anyway, in case others have questions.
Regarding the pitman arm for a '77, not necessarily. Depends on which T kit you bought, but I'm guessing that since it sounds like you're running a stock '73 pitman arm now, you need a dropped arm for a '73 because your draglink is already set up for that year. In fact, you could actually be running a stock draglink right now if you'd only changed out the tie-rod before.
Since it's all new however, your draglink should be sized for the '73.
Correct. Bracket goes with whichever year the frame is.
And also correct, that "normally" with your particular setup you would use both in conjunction. But I would install the pitman arm first, see where that puts your angles, then install the drop bracket if it turns out to be needed. Which is probably will.
Like we say around here, every Bronco is different.
Once you do install a drop bracket, and it turns out to be the right setup, make sure that you have it welded up for a permanent mount. It can be driven with just the bolts just fine, but for proper install, weld it.
And still change that angle on the tie-rod so that the lower draglink end is pointed more upward.
