Updated with more questions-- Time to build/buy a new rear axle...looking for advice.
luderchris
luderchris
SouthEast PA
I think I may just go with 31 spline axles/spool from superior into my Small bearing case and quickly beat the piss out of it over the next 2 years while the Superior axles are under warranty to see if they hold.
How much stronger is a 31 spline Superior axle over a 28 spline stock axle?
luderchris
luderchris
SouthEast PA
I thought a "stock" 31 spline was 35% stronger than a "stock" 28 spline. I figured an alloy 31 spline would be stronger still.
broncnaz
I think a stock 31 spline vs a stock 28 spline is like 30% stronger. I still havent found that chart I had that stated axles size vs strenght increases.
Also a lot depends on materials useds most aftermarket axles are 1541 but thereare some others something like 4140 or something like that. the problem is the harder the steel used the more likely it is to just break. Axles tend to want to twist a little when torque is applied stock axles twiest a lot and over time may retain the twist and eventually fail. aftermarket axles general still twist but a lot less so they tend to break quicker of course it usually takes a lot more to break them.
luderchris
luderchris
SouthEast PA
OK -- My solution was to buy this--
http://classicbroncos.com/forums/showthread.php?t=166042
I pick it up in 2 weeks.
Now, I have 4.10 gears in my Dana 44, so do I change the 9" to 4.10 or my Dana 44 to 4.56. If I change the 9" I will do it myself. If I decide to change the D44, I will have a local shop do it.
There is a 3rd option -- change them both and put in 5.13s. ;D
I have a np435 and 38 inch tires. I get by with the 4.10 on the trails/rocks, but it crawled much better when I had the 33" and 35" tires.
Now -- for you math guys. With my 38's, if I go with 4.56 would it be like when I had 35" tires? How about with 5.13 gearing?
As always -- lets hear your thoughts!
Thanks for the input guys.
Chris
Gravel Maker
Sacramento
You have it a bit backwards...
You are correct on the 1541, infact I don't think the aftermarket companies even make a weaker material anymore but 1541 is a reasonably strong material.
4340 is the axle material when you step up the strength chart. The next step is 300M.
The more you pay (4340, 300M) the more twist they can absorb before failure. 300M can twist up to 180 degrees...They will always be HT (if from a quality seller) and many will also be Cryo treated.
I haven't seen it mentioned yet but there are also 40 & 47 spline variations available. Most desert trucks use 35 or 40 splines. Many Trophy Trucks use 47 splines.
A big step would be a Full Floater conversion to take the vehicles weight off the axle shaft which only creates a pre-load. Losing that pre-load will give you a less strength needed situation if you follow me...
