Steve
Wow, after typing all that I think a good 9" might actually be less then doing a 60.
And much stronger. Unless you bore out the spindles and go with 35 spline shafts a rear D60 is a very weak axle for the weight you're adding, plus the decreased ground clearance. If you want a 1 ton axle a 14 bolt is a much better choice than a D60. If you want to stay EB width, build up a big bearing 9" as Broncobowsher described.
I ran a SB housing with 31 spline alloy shafts and "conversion" bearings, with big tires on hard trails, for years and never broke anything in the rear axle.
