What have you done to your Bronco today?
gmduncan
Annapolis
Decided to take apart my gauge cluster. Eventually will send to Kevin @ Classy Gauges for an overhaul.
joebronco73
Lago Vista, TX
Got a fresh set of plugs and oil/filter on...started a tune on the carb to lean it out. Hoping to replace all the engine bay hoses (fuel, vacuum, etc) and a new pair of belts in the next week...also pulled the trigger on a Painless harness and 3G alternator from WH 😁
Ether
Tulsa
Drilled out/tapped broken header collector bolts, fitted ARP 12pt bolts at the heads
Modded the Zf-5 case for np205, and modified the shifter to function. Also modded the other parking lamp, now both are ready for 66-68 clear lenses.
Ordered more crap, never-ending!
Bought a high pinion 44 for the future, will be cut down, turned c’s eventually.
56f100bbw
Tucson / lakeside AZ
On my 77 bronco, I’ve been complaining to myself about no power I called it a slug, turned out my throttle linkage was out of adjustment, its original, but been modified to fit. Set screw got loose and the arm moved Easy fix now I’m happy.
56f100bbw
I could probably even get a speeding ticket now
Ether
Tulsa
PB booster/pedal rod, hydraulic clutch master and rod modified and final mounted.
Swapped in a stainless vent window, what a pain! Also repaired the latch handle to make it close completely, drive out the pin and put an additional thin washer behind the wavy washer.
Looks great! And got rid of the cheap/separating non oem glass I had in that window.
