What have you done to your Bronco today?
Wyflyer
Installed the JB twin sticks on the 72 halfcab chassis build, then pulled the D20 and pulled the shift fork shafts out and modified them so I can use all the shift positions. Reinstalled everything and fit the JB sticks and verified they work.
These are the twin sticks i won at OCBR 2 years ago!! Thanks again JB!
put on my new tires. wired up my H4 headlights now I don't have either brights or dims ?:?not sure yet
Now that sounds like a great thread-starter!
Of if you also installed a relay kit at the same time (or didn't) joint in one of the other similar discussions.
Interested to see what you find out. Probably something simple though.
Hopstr
Okay, here's the photo. Moved my front end forward 2".
sprdv1
REBEL
Very nice. Better late than never. 👍👍
Skiddy
will do, be on the lookout;D
jray
Installed new shocks on all four corners and man, did it make a difference!
Skiddy
got my headlights working, had two wires backwards%) replaced the fuel line, now I think the transmission lines got jealous, I have fluid spraying out somewhere:mad:. Took it down the road with the new tires on, forgot how bad a spool is on the street%) guess the boggers were so wore out that I really couldn't tell much.
cleaned out a tote that I got with the bronco over 10 years ago%). found some nice chrome headlight bezels, a instrument cluster:cool: a bunch of lenses too;D
Cvcoda
Omaha, NE
Got the front end all pulled apart to replace all of the bushings. Found one of the c-bushings installed upside down on one side...
Miker
Put some Dynamat on the underside of the hard top
Put in 32 sq. feet of Dynamat on the underside of the hard top.
Brent13
Colorado Springs
Cleaned the third member housing, pinion housing and yoke. As clean as I can get them, I'd eat off of them right now. Taking to powder coat tomorrow. Hope to to have the axle housing to powder coat by Friday. Waiting on a weld-on truss from Toms. That will take me probably three nights of stitch welding, trying to avoid warping.
ribbits
WOW,, almost forgot?? Dirt Daubber city!!
The other day I opened up an old building located on the upper end of my property.. Don't go up there very often and have not opened this building in years.. Last tag date was 1991.. Now I've got a couple more projects to add to the list..
tasker
all knowing of nothing
NH
wish I had those kind of buildings!! :cool:
Golfball
Looks like a fun project. You keep the yeller one and I'll come pick up the brown one;D
fatboy
Glad to be here.
New Hampshire
Sorted out the old fuse box. Had a couple of broke wires and I needed to figure out what went where. Got the heater box pulled out so that I can put the rebuilt one in.
MikeKC130J
Installed 1in lift from Wild horses. While it was not fun to do, definitely not the worst job.
