- Joined
- Jun 1, 2007
- Messages
- 371
I think there are a few things that pushed me to a 609 front, whether true or not:
-The 609 exists because the 9” center section can be built to be stronger than the D60, but the D60 has stronger outers. Even though the ring and pinion are smaller, the hypoid angle and the way the gears are cut make them stronger. (In reality, maybe it is the interchangeability of the 9” that makes this axle exist.)
-Very high pinion is nice for clearance and driveline angles.
-Removable third member is great for repairs, especially on the trails.
-Light axles drive better.
-I love axles and want to do something overkill and a little different. Building the axle from scratch allows me to do this.
-I’ve become a little fixated on the 609.
I looked at a ProRock 60 and a ProRock 80 front at one point. I was interested in the 40 spline axles. Dynatrac told me that the ProRock 60 uses 1550 U-joints while the ProRock 80 only used 1480s. They also said they don’t recommend the 40 spline on the D60 because the R&P becomes the weak link. (I also prefer kingpins.)
I hate breaking and would rather root out any weaknesses I can now. I’m considering a 14b front but the low pinion, and to a lesser extent the weight, concerns me. The Dana 60 might just be what I need, maybe even the classic D60/D70 Snowfighter combo. Maybe I’m overly concerned about the D60 R&P strength, and maybe 40 spline is a worse option than 35 spline. Or maybe a high pinion isn’t that big of a deal (the rock bouncers don’t seem to care).
You say your D60 is your weak link. What do you find yourself wishing for? A 14b front? Would you trade your HP D60 for a LP 14b?
