1 1/2 days for first side...1/2 day for the other ... must be a hundred times already that I've jacked it up and down trial fit for clearances..
If I'd just gone with a full width axle the trial fit would be the final fit...I tacked and cut off upper and lower brackets at least 6 times with different combinations of angles and spacing each time! : )
Maybe I should learn geometry and do it once!
Tire hit the inner fender, tire hit the strut, strut hit the upper bracket on full droop, ORI inward lean angle would be perfect desired number on each of the above but ... I move the brackets and the ORI angles wouldn't work...eventually got it all to work.
