No pics tonight... should post one of all the dang smoke that we've been living in since mid July... forest fires on the West Coast are much worse than "normal"...
Been working on moving all the wiring, connections for winch, solenoid connections, etc all this just on the pass side. Will re-route my battery cables from inside the frame like they've been for a dozen years to up against my rock skis under the floor inside conduit. My rock skis are 4" top-bottom and stick out from the body the same amount as my Gorilla flares which helps to keep them from ripping off and should protect the cables tucked up against the floor pan and the rock ski too.
Battery's new location will be in front of the new 40" long fender well on the pass side directly behind the B hoop, vertical, and tucked against the side panel, moved from where it's been for years which was between the tailgate and wheel well on pass side.
I will mount it directly off the cage pillar (up high enough to clear the fender by 1/2") and then box it in entirely with a quick release or hinged lid for easy access. But NOT how it's just leaning like it shows in this hurried pic!
I want to install a battery selector switch for a quick kill/shut off also. Always liked that idea in case of a cable getting pinched on a roll over or somehow. The inside of the box will be non conductive, lockable, and the battery switch will be outside of the box, easily/quickly accessible.
Pics when I get there...I put the RCV's in the housing (had to take .115" off the long axle), cleaned parts and installed new kingpins, kingpin bushings, etc in tonight. Letting the spindle hubs, brake brkts and anything painted to dry tonight and will put some zinc on the spacer btw the disc bracket and the spindle.
Checked about 8 things off my list this weekend... but did notice I get to pull my ARB apart to turn the outer diameter down on the lathe some so the thrust bolt will ride against the ring gear...thought I was done with that, missed it earlier...did it to my old grenaded ARB a few years back so...
