ntsqd
heratic car camper
I would expect that Mass Air would yield a finer resolution of the air being ingested by the engine than can Speed Density. This may have more implications for emissions than it does for power. Mass Air seems to have long been the preference in the Ford World, but in pre LS days Speed Density was king in the GM world. I'm betting that this has changed now.
What I would be interested to know is if guys who trailer their OEM EFI systems to a significantly different altitude have those same kinds of issues. I suspect not, but I don't know that. I suspect that it's symptom of what are basically low end, fairly crude systems.
I am starting to think that such an ECU like the Haltech may be a necessity rather than a nice to have for this engine. I just used their ECU Guide with some guesses and ended up here:
www.haltech.com
Not inexpensive, but how much time and money has been spent diddling around already?
Right there about 1/3 down the page: "Load sensing by Throttle Position (TPS), Manifold Absolute Pressure (MAP) or Mass Air Flow (MAF)" so you can use whatever you want for that input. Maybe D/L there programming software to have a look at it and see if it is something that you can work with? https://www.haltech.com/downloads/
HT-151376 Elite 2500 + V8 Small/Big Block GM, Ford & Chrysler Terminated Harness Kit - Haltech
HT-151376 Elite 2500 + V8 Small/Big Block GM, Ford & Chrysler Terminated Harness Kit.,,,Bosch EV1,. Outputs: Up to 8 injector and 8 ignition.. Suits:V8 GM Small/Big Block V8 Ford Small/Big Block Chrysler HEMI. Includes: Elite 2500 ECU with DBW and Race Functions, engine harness with fuse block...
