ntsqd
heratic car camper
At least you don't have to pop-rivet a piece of sheet metal over the hole in the piston so that you possibly make into the pay-out money.......
Yeah, it's real for sure Paul! IAC that failed b4 startup, 3 TPS's, two O2 sensors... & that's just engine mangement... frustrating as heck!That’s becoming a great fear of mine.
When and and if I finally get around to finishing some of my projects, I don’t have the time in life anymore to do them over again!
Can’t just keep redoing things due to defective parts.
I'm in Michigan and Silver Lake Sand dunes are only about 40 mins north of meJust one cyl with zero compression. Whew...
Thx for the advice about deleting the learn table.
Clueless on that but I'm sure I can find a post somewhere on how to do it. Thx
Which dunes are ya hitting?
lol
Only being 40miles away would be a hard temptation to resist a couple times/month!I'm in Michigan and Silver Lake Sand dunes are only about 40 mins north of me
Yes, IAC motors are garbage and I honestly cannot count how many I purchased before finding the one that would work for me.,I've spent at least a couple hours every day on this since the IAC failed. Had a very helpful hand from a CB brother with some tunes and settings and I still couldn't get it.
Hauled it 110 miles to the only guy anyone local in our tractor town knows can tune Dominators and Terminators... He's tuned mine b4.
Back to the dyno again... New parts are crap. 3 TPS's, 2 O2 sensors and 3 IAC's in three years. IAC stepper motors aren't always the same so I can't just plug a new one in. After spending 30 hrs trying different settings and the same thing over and over and over again expecting different results (definition of insanity) I took it back to him and he said with my cubes & my cam it's impossible to get the idylic #'s the internet and Holley say I should have. He had it re-dialed in within 2 hrs. It won't cold start yet w/o it dying once (never died this quick before) w/o dying once or twice within 4 seconds of it firing so it must be the engine start ASE circuit. I will play with it and see if I can get it.
It runs great when warm. I had a fouled plug probably from all the dinking around and bad AFR #'s the past 2+ wks.
Adam- I'll send you the tune so you can see what you think.
Yeah, honestly, there is no way that's going to work out for you. You'd need to leave it with him or figure it out yourself.So dang hard for dialing in cold start-up when you only have one- cold start after you tow it 110 miles each way to try to get it dialed in.
O'Reilly's Standard is what I am using now. Thanks for posting up as maybe I'll be good for a while.Yes, IAC motors are garbage and I honestly cannot count how many I purchased before finding the one that would work for me.,
Which type are you set up for and can you post a pic of your setup?
I don't know how much the steppers are different from the pwm ones, but I found that some are ok with reversed flow and others are not. For example, on the stock config for that motor, it might be set up so that it needs vacuum to get it closed and if you install it reversed, it can't close and your idle won't go dow and so you aren't getting the position your ecu is commanding.
For the actual valve, I had the best luck with Standard and getting them from Oreilly Auto. My rabbit hole search started after getting a bad stock replacement from Rockauto.
And it there any way to know for sure that it's actually going to the commanded setting? For the pwm valves, since they have an inlet and outlet hole, I could see and I could also blow through it from each side and feel the resistance (when connected electronically but not mounted).O'Reilly's Standard is what I am using now. Thanks for posting up as maybe I'll be good for a while.
'98 Camaro part
Pic would not show much as it is buried unless I zoom in to show just it with the wiring connector so here's a pic of it in an ad.
I'll show a pic of my IAC so you can see it's cylindrical shape.
