bronko69er
EB Addict
superslowmoe said:Have any specs on the firewall location for the MC and maybe rod length(stock?) or pivot location on the clutch pedal.
Looks like that might be the stock hose from the truck too. Any heat/header issues?
You'll likely have to re-do some exhaust routing due to the new crossmember.
I used the BC kit which came with a SS braided MC to slave line but header heat shouldn't be an assue.
The MC will partially share the original speedo cable hole and the speedo cable needs to be relocated. I just opended the hole up enough to bolt up the MC and made a slot to slide the speedo cable down in. Others have used the old clutch rod hole.
Chuck @ BC can give you the correct placement position for the rod end. I'd have to go measure mine and it may not be perfect.
