Anyone install a 5-speed tranny? which one?
laserfish
I have a NV3550 from a Jeep that I installed in 03 and it has been flawless. Used the High Impact kit and put a twin stick on it. I also put a 1 inch body lift on, 4:11 gears and 33's at the same time. The shifter location is perfect and natural. Can cruise the highway at 70 with ease and put it in low and chug through or over just about anything i want. One of the best mods we made.
sykanr0ng
I am running a stock 3 speed w 4:11 and 38.5 tires now and think this is the way I want to go on mine, like keeping Ford stuff on it. Is the NP205 what came in F150? And did you have to modify drive shafts? Seems cheaper to go this way than all the adapters needed for other trannies and still handle some wheeling too.
In F150s yes, but not in that year they were used 1973-1979
Getting hard to find and expensive.
Bakersfield
So I've been in the debate of which of these two transmissions to purchase for my 74. I have a 351W. I plan on doing a 3.5" suspension, 1" body, either 33s or 35s, however, I've never owned a standard transmission vehicle but have always wanted one ( i know enough info on how to drive a stick if a zombie apocalypse were to happen). I'm wanting to build my bronco to be able to drive several hours to either the mountains or beach and then take it off roading. Not trying to do hardcore four wheeling but some fun trails.
I was leaning towards the AX15 kit because it'd be a new transmission but second guessing myself if i should go with the NV3550 because of the gearing. So I think my real question is, for what I'm wanting to do, is the AX15 going to be that hard to learn to drive both on and offroad? Or lets say i do go with the AX15 and instead of the Dana 20, going to the atlas II t case to help with the lower gearing for off road?
Any input is appreciated. Thank you
JGO
I've had them all (mostly), and I don't think the medium duty 5 speed shifts that much better than the heavy duty to justify. I prefer the heavier duty 4500/ZF tranny. They are all fantastic! just get the right ring and pinion and you'll love it. (P.S. I have a 3550 w/adapters for sale0
sykanr0ng
I would choose the M5OD-R2 over either of the AX15 or the NV3550, it takes fewer adapters since many already have the SBF bolt pattern, is a little stronger, and is more common.
My personal choice for my own Bronco is the ZF5, but that is for harder trail use than you plan.
The Atlas II is a transfer case for much harder trail use than you plan, it would be a waste of over $2000 for you.
blubuckaroo
Grease Monkey
Ridgefield WA
Like I've said before, study the gear ratios. Not just first and fifth, but all the gears. That's the difference that should make you choose one over the other.
RPM289
I am leaning more toward the ZF or M50D just because I like Ford stuff. I think I know where a 2wd ZF is but can you swap tail housing between 2wd a 4wd or does shaft have to change to?
sykanr0ng
Tail housing and shaft change.
You can probably find a 4x4 ZF for what changing those cost.
boonz28
Anyone who has done one of these swaps care to post a picture of the trans tunnel and tell which trans you've got?
Just trying to visualize where the shifter is located with the various options.
Seth
Seth
Note on the Mazda version. Depending on year it can come out in 2 different locations. Pre '96 is further forward, post '97 is further back. So if someone posts about the Mazda, be sure to note what vintage it is.
Slednut10
Guru? That's funny!
M5OD 97+ (Sourced from an 02 4x4 4.2 v6 truck)
Crush
Greenbottom, WV
there are actually three shifter positions on the M5, pre 97/97-03/and 04 up. the 04 up is farthest back by about an inch and a half
I have a 351W.
I don't think you could go wrong with either one. Or for that matter, any of the other ones being talked about. But just from your description and not knowing you or your driving habits personally, I'd say just work with the AX15 and don't worry about the minor differences. In part because of the "new" aspect, in part due to the higher torque rating, both of which seem good reasons and no real negatives for you.
The lower first gear would seem a benefit (it's why I chose the 3550 over the AX for myself) but the 351W will help with that when it comes to letting out the clutch. And the fact that your trail needs are not going to be particularly stressful either, the need for the lower gearing is not really high and the AX should be fine.
Either one is a huge improvement over the manual trans that would have come stock!
What about that engine though? Stock? Modified? Fuel-injected? Those also make a big difference in your other choices. Maybe even including the transmission if you have a real fire-breather under the hood.
You're right on the money with the low-range benefit of the Atlas being a good way to compensate for just about any differences in off-road gearing. But here again I doubt you'll find it necessary.
The downside to that logic is that, if you do stick with the 20 at first and decide later you would rather have had the lower gearing, you have to go back through it and swap the 20 for the Atlas. If you're doing this stuff yourself, perhaps not a big deal. But if you're paying a shop to do it, then do it again, it takes on a higher level of frustration. Easy to sell the old adapter though, so at least some of the cost is mitigated.
Frankly though, if the cost of an Atlas is not intimidating right off the bat, then putting one in right from the get-go takes the cost of the adapter out of the equation, saves you a bit of money (in spite of the obvious higher cost of an Atlas over a simple adapter) and gets you that lower gearing that might (or still might not) come in handy. I love Atlases, but don't really think it sounds like you'll be needing one just from the tone of your description.
Do you think you might ever decide it's just too much fun and start doing harder and harder trails? Or just a daydream and the simple dirt 2-tracks leading to a hunting lodge or lake going to be the way things go? If the latter, stick with the 20 and pocket the Atlas money for the cool paint job.
Best thing you can do no matter what, is just like someone said and choose the right differential gearing for all-around best performance in your arena. This can make up for many shortcomings elsewhere. Both on and off the road.
The minor difference in gearing between the two boxes you mention is not going to be enough to either make or break your off-roading prowess (until the trails get more tricky) nor your ability to learn how to shift. Or more accurately, how to get rolling from a stop!
The lower first gear of the 3550 would be slightly more forgiving of getting a Bronco rolling, but the difference between the two first gears should not be hard to deal with. Especially with the 351 and the correct diff gearing.
So you probably can't screw up the transmission choice with either one, unless you screw up your ring-n-pinion ratio choice first.
To that end, check out the calculators online (here's one such: https://www.yukongear.com/calc_rpm.aspx) and see where you think you'd like to be. Don't fear the gear, but no reason to over-do it either for a mostly street driven rig.
4.56 comes to mind for 33's, and probably the 35's too. With the right engine of course.
Or with 4.88's being the choice if you think you'll spend more time off-road than you originally thought. Or even 4.11's if you just want the lower engine speed on the highway and your engine is strong down low and burns clean through EFI. And you don't happen to live where the roads are really hilly.
Otherwise stick with the 4.56 I would think.
What other equipment will you have that might make the Bronco really heavy or have greater rolling resistance?
So you can see that asking your questions and making specific decisions up front will help, but every time you waffle back and forth over tire size though you change all the other parameters! So make that decision and adjust the other stuff accordingly.
It's all about the tire size and R&P ratios...
Good luck!
If your head ever starts to hurt with all the choices, step back and and relax... While you try to choose a paint scheme!;);D
blubuckaroo
Grease Monkey
Ridgefield WA
With a 351W, I'd be concerned about the maximum torque rating of the tranny. I can't find the rating of the AX15, but the NV3550 is 300 Ft Lbs. That's within the range of a 302, but not a 351W.
Of coarse, you wouldn't always be applying that much torque, but why have it if you can't use it?
ntsqd
heratic car camper
Upper SoKA
AX-15 is essentially the same as the Aisin R series trans. Can find a max torque rating for that.
blubuckaroo
Grease Monkey
Ridgefield WA
What is the max torque rating of that Aisin R?
I have the NV3550. That's one of the reasons I plan to stay with the 5.0/302 platform on my engine build. I realize there are probably lots of NV3550s out there running behind bigger motors, but what tempt fate?
ntsqd
heratic car camper
Upper SoKA
No idea, but it can likely be found should a person care to look hard enough. I'd start with Marlin's page.
The Woodlands
Where can I find a list of donor vehicles for the NV3550 and AX15 ? Do they need to be out of 4X4 donors ? What is the difference ?
Nothing Special
I don't know about an entire list, or about the AX15. But I do know the NV3550 was used in Jeep Wranglers and Cherokees around 2000 (sorry I don't know what year range either).
2WD transmissions won't allow you to attach to a transfer case. You need to get a 4WD output shaft and 4WD tailshaft housing to convert a 2WD trans to 4WD, and the conversion requires completely disassembling the trans, so usually it's not worth it. But if you are going to be converting the trans to attach to a transfer case that it doesn't normally fit you'll be getting those parts in the adapter kit anyway, so it might not matter if you start with a 2WD or 4WD trans. But I can't say that for sure, maybe others can chime in, or else check with whoever makes the adapter you are planning on using.
In my Bronco I switched to an Atlas transfer case when I went with the NV3550, and the Atlas is made to be a direct bolt-on to the Jeep trans, so I didn't need to deal with any adapter. I'm not sure what's involved if you are planning on sticking with your Dana 20.
