BP 306 Oil Consumption
badandy73
Broncoholic
Hey All,
Experiencing in my opinion higher than normal oil consumption on a fairly new crate motor and wanting to get some input.
It's a BluePrint 306 Bronco edition that I ordered directly from them and installed about two years ago, only has 4500 miles on it. Last oil change was in August and since then, I've put 1500 miles on it and it's burned 3 additional quarts, roughly 1 qt. every 500 miles.
I've been in contact with BluePrint and they have just said that it's probably still breaking in, to keep an eye on the oil level and to drive it like it's stolen to help fully seat the rings. Been running non detergent 30 weight in it per a previous shops suggestion to help this process along, which at the time BP agreed wasn't a bad idea. Last mechanic that had the truck for some carb tuning said on the next oil change to switch back to non-detergent conventional along with a bottle of zinc additive.
Am I wrong to think this is excessive for a built motor going on 5k? Should I be pushing back on BluePrint when they are telling me it could be 5-10k before it'll quit using oil?
Timmy390
Conway, AR
I only run 30 weight non detergent to break in a flat tappet cam. I also use some additives in the process. After that good ole 10w40 or Rotella 15w40. No issues.
Drinking a quart every 500 is allot IMO. Is it smoking? Have you checked for leaks? How's the PCV plumbed? What heads? Were the head freshened up?
Tim
I've had engine take 10k to break in. But you could tell they were breaking in as the oil consumption was dropping off during that time. Not steady or getting worse.
Yes, valve covers (baffles) and PCV can cause oil consumption issues if not right.
Should be running detergent oil. Don't really care about the initial break in oil, that gets changed out fast enough. But after the first change it should be detergent. It helps get the junk in the oil into the oil filter, not settling to the bottom of the engine.
JB Fab
Exactly what he said, drive it hard, downshift often........
jamesroney
Fremont, CA
There were 57 Million new cars sold with gasoline engines in 2020. There were 60 million sold in 2021.
ZERO (statistically) ever went thru any kind of break in process. The last Ford 302's were sold in a Ford Explorer. Just how much "break in" do you suppose the average soccer-mom performs on a new Explorer when it drives off the lot?
It's all nonsense, witchcraft, and voodoo. And excuses for mistakes in build quality.
Modern roller cam, cast iron cylinder, water cooled passenger car engines do not need, nor do they get the luxury of "break-in." (Nobody in their right mind installs a flat tappet cam in a small block ford.)
When you rent a car from any agency, they don't say: "Here are the keys to a brand new car. Please watch for excess oil consumption. If it still burns oil after 4500 miles, you're driving it wrong..."
...roughly 1 qt. every 500 miles.
Yes, far too much for a properly built engine with modern parts and 4500 miles on it. But that's "normally" too. Not all can be the fault of the engine builder, but a good part does usually fall on them. Time to drill down some though to be sure.
Do we know what kind of rings and things BP uses in their engines? Roller or flat-tappet cam in yours? Do other members with this same engine (there are quite a few I think) have the same consumption? Even for the first 500mi which "might" be acceptable. But certainly by no more than 1,000 miles should your oil consumption be near zero in 5,000mi.
Or at least no more than a quart in 2,500 miles on certain engine types and setups.
It's not necessarily dishonesty on their part, but it could be. Mainly they're trying to make sure that all things are covered and that you are aware of what should be going on.
Do they know all components you're using too? Have they asked about the setup and tune? PCV valves and such? How you drive it and how often?
Stuff like that?
I've heard they're pretty good at backing up their stuff, so not to worry yet. Unless there is a warranty that is. If it's only two years and two thousand miles, it's time to call in the troops. If it's good for over 10k or they've said they will back it up in writing if it does not improve in that amount of time, then do what they say and run it as often and as hard as you feel like.
Keep them aware of all the details and do it in writing/e-mail so that there is a record of communications. Not to be mean, but to CYA as in "just in case" they don't agree it's a problem in the next year or two.
But drive it as much as you can.
I wonder who the heck recommends non-detergent oil for more than the first half-hour break-in anymore? Or at the most, the first 250mi or so of driving? Usually not even that though... To that point, are you sure you understood what the person was saying about "break-in" and that they didn't mean just the initial 500 miles or so? Doesn't BP do an initial run-in of their engines before shipping? I think they do, but maybe you know for sure.
Basically though, by the time you were driving it you probably should have been running the oil you'd be running in it for most of it's life. Or if you're planning to run synthetic then you can wait for a bit if you want, to let things seat better. Which is sounds like they should be doing!
I still think regular old engines might benefit from non-synthetic for 5 to 10 thousand miles, but that's old-school thinking (which is what I am most of the time) but still might depend on what components BP uses in their engines. Lots of new (most of them?) engines from the big car companies run synthetic oils right out of the gate with zero miles other than an initial run-in that they might go through at the factory. I'm not sure what all the differences are between a Ford 302 based engine, and say a GM LS series, but the list could probably fill a book. However I don't know which ones dictate that one engine can run synthetic it's whole life while others might benefit from waiting a few thousand miles.
Probably piston rings and piston hone patterns mostly.
Someone is speaking some sense anyway, but I would not wait. I'd spend the extra money now and change to your choice of regular motor oil now. Not later..
And zinc additive is for flat-tappet cams. Is yours flat-tappet, or a roller? Does BP offer both? If you have a roller you don't need the additive.
No and yes.
As said it's excessive, but as long as they know already and you've been in touch with them semi-regularly to keep them up on what is going on, I would not necessarily try to make them do something until you do reach that 10k mile mark. Things might change by then. Or they might not...
So keep daily driving it and use it like normal. You should not need to beat on it to break it in.
I understand why they want you to be hard on it though. They're trying to ensure that it is in fact a break-in issue with you perhaps driving it only occasionally and babying it too long. But it should only take some moderate beating to get things to all play nice together inside.
And maybe I glossed through the discussion already, but did you answer the questions about the PCV system? Including what valve covers, what PCV valve, and what air return you're using?
What temp thermostat are you running? Should be a 192-195 thermostat for this engine.
And what conditions are you driving it in? Does it fully warm up? Do you drive it for extended periods? What about extended freeway jaunts?
Oh, and what is your gearing and tire size and transmission type?
All things to think about.
As for referencing new cars, there is a lot of new technology in the manufacturing. Ring packages are hyper thin. Spray in cylinder wall liners are built up to final dimensions, not cut down. Blueprint is rebuilding used blocks (new blocks are coming soon) and dealing with what a rebuilder has to work with. There engines are very good, but don't have the R&D that the OEMs have. Add in Blueprint has so many unique applications. Not just the vehicle the engine goes into, but all the little details that go with it. What intake is used, what valve covers, the list is endless. OEMs know every engine will be installed exactly the same.
And yes, new cars still have break in procedures. Not super rigerous. But you will often find lines in the owner's manual limiting towing or high speed driving for the first bit of ownership. It is generally ignored, along with most of the owner's manual that is never read.
toddz69
So these are not "crate engines" in the pure sense of the word? I thought even the 302's were new castings rather than used. Interesting to hear that.
Glad new ones are coming, but yes that definitely can change things. For sure makes the "what do they use and how do they use it" aspect an important thing to know.
Yeah, Blueprint has always used "seasoned" (i.e. used) blocks for their Ford builds - bored 0.040". They introduced the new castings at SEMA in November. I chatted with them again at Barrett-Jackson in January and asked about the new blocks and got a pretty firm "we don't know when we're going to get them" response from several people there.
As far as the oil consumption, when I hear stories like this, I'm reminded of an experience we had with our '77 Ford pickup back in the mid '80s when we replaced the 351M with a rebuilt 400. The new engine consumed a quart every 300 miles and the mechanic at the shop that did the work kept stringing my dad along, telling him the oil consumption would go down, blah, blah, blah... Well, before you know it, the warranty period was up and Dad got screwed. They ended up driving that truck for about another 7 years, faithfully adding oil every 300 miles. Want to get my 82 year old dad really mad these days? Bring up the story of that engine...
All this to say - like others have noted - keep your notes and communication with them documented. I'm of the opinion that you're not going to like the outcome on this saga.
Todd Z.
jamesroney
Fremont, CA
Uhm...agree to disagree.
This is the part of the game where I say "bull..." and we both turn over our cards, and then you drink.
The engine in question is a Small Block Ford 302. My specific reference was to a 1996 Ford Explorer with a Small Block Ford 302. The Owners Manual for the 1996 Ford Explorer is still available on the Ford website, and the "break in" page is pasted here. It doesn't limit anything relating to the engine. It tells you not to use the wrong oil, and don't rely on the brakes.
That was 1996. 25 years already? wow.
  • explorer.pdf
Timmy390
Conway, AR
I recall seeing a "break in" period listed in my 1990 Mustang GT......... I did a search....
According to the owner’s manual, the 2021 Bronco does require a break-in period. For the first 1,000 mi (1,600 km), Ford recommends you avoid driving at high speeds, braking heavy, shifting aggressively, or using your vehicle to tow.
As to the Op's issue......My money is on valve steam seals or PCV
Tim
badandy73
badandy73
Broncoholic
Follow this post to see my solution to what you are experiencing. Last summer, I drained off about 1/4 to 1/3 cup of oil every 1000 miles.
https://classicbroncos.com/forums/threads/burning-oil-troubleshooting.303032/page-2#post-3293478
Thanks Master Chief. I came across that thread last summer when investigating this and/or the issues I was having at the time with the sniper that came with the engine. I may need to take a closer look at running one of their PCV valves to alleviate the issue.
badandy73
badandy73
Broncoholic
Tim
Doesn't smoke, maybe a slight puff here or there on cold starts but nothing significant. PCV valve is in the passenger side baffled grommet running right into the front PCV port on the carb (Edelbrock). Replaced the one that came with the motor with the same one last summer just to be sure. Napa # 29333 or 2221 on the valve itself. Application that matched was from a 96-01 Explorer 5.0. Heads are the BluePrint spec'd ones that came on the motor, HP9009, 60cc chamber, 2.02" intake, 1.60" exhaust valves.
badandy73
badandy73
Broncoholic
Running the Proform (Ford Racing) 'slant edge' valve covers. They replaced the scott drake bronco script valve covers that came on it and leaked immediately, blowing oil from the breather, due to the poorly designed baffle/ tube on the breather side (drivers). They have a sheet metal 'window' that is supposed to act as a baffle but directs the oil directly up and out of the breather neck. The Proform's solved that problem and hardly get any vapor out of the breather. Much better baffle system and with the geometry of the valve cover itself, the breather sits on top (horizontally) instead of off to the side directly in line of the rockers.
Purchased a case of the blueprint break in oil with the motor, and ran it for the first 500+ miles as per their break-in procedure. Then changed it for Castrol GTX conventional 10w-30, only went to the non-detergent last summer on the suggestion of the mechanic I was working with at the time. Just did an oil change tonight and went back to the GTX conventional.
badandy73
badandy73
Broncoholic
Stuff like that?
No and yes.
Paul,
Lot here to digest but here goes. Don't know the exact specs on the rings necessarily, but yes, its a full roller motor. They are a fairly often mentioned engine on here, haven't heard of anyone having these same issues, but would be great if someone chimed in for a comparison on their experiences.
They do have a 30 month/ 50k mile warranty, so it's not like I have 2 more years to figure it out. I did communicate with them early on when I first started noticing it right after the break-in period and we did have fairly steady communication going on up through last summer. The rep I was dealing at the time assured me that they wouldn't leave me hanging and work to get it resolved one way or another.
BP does do a dyno pull on each engine, mine came with all the numbers and graph that matched the serial number on the block. As far as an actual separate break-in, I'm not sure. I did follow their procedure explicitly as previously mentioned using their break in oil. They have you 'prime' it before you start it for the first time, ignition disconnected and crank it over to verify oil pressure with a mechanical gauge, which I did and all was good there.
Skipping down to your last paragraph... Installed a Motorcraft 190 thermostat to start with, which seemed to be preferred with the sniper. Literally just swapped it out for a Robert Shaw 180 that I ordered from you guys. With the 190* it would get up to 205-210 fairly easily cruising on the highway even on 65 degree days. So dropped it down to prepare for the summer heat and thought that would play better with the carb I have on it now. Typical trip into work is 20mi of highway, 65-70 mph, so it gets plenty warmed up but haven't had a lot of long trips with the issues I've had and now gas prices being $$. Running a C4 with 4.11's, so it gets spun up pretty good on the highway, 3-4k.
BOBS 2 68S
Hudson, CO
I have a Blue Print 302 and had the same problem. They told me to check the intake seals, found oil in intake runners in head. ( I installed a new Weiand intake ) Gaskets didn't seal. Replaced gaskets and tighened everything to Ford spec's. Saw oil off rocker arm was splashing stright into the PCV valve and fouled it. Added a baffle under PCV hole and new PCV valve fix my oil burning problem
blubuckaroo
Grease Monkey
Ridgefield WA
My vote is either a PCV siphon problem or intake manifold gaskets.
Aftermarket cast valve covers can be a problem. All of the ones I've seen have only a bent piece of sheet metal for an oil baffle for the PCV openings. In comparison, steel valve covers have a real baffle that's sort of a labyrinth affair that is designed to separate the oil from air. My new Blueprint engine came with chrome steel valve covers that has the real baffles. I'd like to replace them with something nicer, but I'd rather have an engine that doesn't burn oil.
Vanity has its price.
Also, we would all like to think our intake gaskets are sealing properly, but assuming that all those surfaces between the heads, and intake are perfectly aligned and fitted is a mistake. It should always be checked before final assembly. Previous machining of the head and/or cylinder deck will affect the fit of the intake manifold. Sometimes the intake manifold will need to be machined to make the runners line up properly.
I had a 302 once with only 60K on the rebuild that started fouling plugs, using oil, and running poopy. I assumed it was just worn out, but it had good cylinder compression. It turned out to be leaky intake manifold gaskets.
