Dan Wheeler's Astro Hydroboost Thread
Bronc076
Sierra Vista, AZ
If you have the 4x4x2 box you will need a -6 AN to 5/8-18 NPT fitting:
- RUS-640380 Fitting, Straight, -6 AN Male to 5/8-18 in. Inverted Flare, Steel, Zinc, Each
you may also need a fitting for the steering box low pressure return which I believe is 3/8ths inverted flare. You can buy a little piece of pre-flared hard line from NAPA with fittings for this.
Is this info correct for the stock 76 power Bronco steering box?
Bb975d
Mounting problem
Because I have no body lift I have to mount the hydro boost inverted and the output lines are super close to the valve covers. Any ideas on low profile 90 fittings?
Stutsmo
So where does the Summit proportioning valve hook up? I am guessing on the front brake side since it has the bigger reservoir but just want to be sure.
toddz69
Any proportioning valve always goes in the rear brake line. The front brakes should always receive full pressure.
Todd Z.
Stutsmo
Ok Thanks Todd. I wasn't really comfortable "Turning down" the pressure to my front brakes.... Just didn't seem right since the front provides most of the braking.
seatownx
Hydroboost advice
this is great stuff, i have a couple questions...
I am running a 302 with standard valve covers
chevy K5 blazer disks and rotors in front drums in the rear with an adjustable proportion valve
looks like ill be purchasing a saginaw pump and pulley
1) using an astro hydroboost do i need a bracket between the hydro and the firewall?
2) what do you recommend for a master cylinder?
3) will the MC bolt straight to the hydroboost without a bracket or plate?
DanWheeler
DanWheeler
Kirkland, WA
1) yes, you'll use the bracket that comes with the hydroboost. It's a square piece of steel about 4" x 4" you may need to modify it to clear some of the bolts on your firewall. (see pics below)
for mine, I had to cut a corner off the square bracket then I drilled some new holes on the plate to allow it to mount using the factory MC bolts.
2) I would recommend a matching master cylinder from the donor hydroboost. That way you know the fit together as designed.
3) Yes, use the matching MC as from #2 above and it will easily bolt together.
y4mZNQxA65jRgpmHsep1f3OJ3qW1u2nJWHHluvHRFqvqX3hTmT-E0zUiTqOTsgbHm7COi7yFs6abqojRrJynTraAHU_vei1ShGyM6z5XzD8LSx91Ty8dRtHxkRivRGI06Z6ggeJMgwl6LLs_2cMrFOgj_iPNhm6uTvR0ykEgEgK_6wfdEgQu3WawjpONG46KiDM2B2OcNRqLk__UWss8qLdfQ
y4m3x4ujN2Vo1UJQIvaRiOkTpdEnhuWVLANutuQ9poXXEeqcdMBj5PAzwuqpvnz3v_cMGyoiYLJDkLeT53yQqZSwQOUO7nQZyf9LTHa_kFZXU1WLUaAJPTtLAvMwXUXYre0BVNaGyNyhhzbyIxoypTT3erOQt14itEAoXKJRHmw0gf6xHqdYqY4Oj_T3Sy2w3kW7dpuTP1mnIyDQ5gcAJE14w
DanWheeler
DanWheeler
Kirkland, WA
I fixed all the pictures on page 1. Got some spare time on my hands these days. Just had to move everything over to my Microsoft One Drive and re-link all the embedded photos.
hoping some day I could get around to this for all my other threads.
zainyD
Thank you for updating this! The pictures make visualizing this conversion so much easier. I just picked up a Astro HB unit from the wrecker yard this morning along with a Saginaw p/s pump.
Edit: One question, what threading die and coupler did you used to mate the Astro and OE Bronco pushrods together?
CDavis
I’m hung up with my local parts stores trying to figure this out. What fitting did you use on the master cylinder to get it to connect to the proportional valve? Car quest and Napa seem to be a no-go. Not sure on thread size and no matter how much time I spend searching google I can’t get a definitive answer on which port is for the front or rear. The speculation on that is all over the place. Is the larger front port with the smaller res for the rear brakes?
DanWheeler
DanWheeler
Kirkland, WA
yeah, this is a tough one, in 10 years I have still not been able to figure out what fitting sizes those are that go into the Astro MC.
The front/rear port question is also full of differing opinions. But... I believe you can tell which is front and which is rear very easily by looking at the size of the reservoirs... The port nearest the bigger reservoir must be for the front since disc brakes have larger caliper pistons vs drums. Could be wrong, sure, but it seems pretty logical.
Back to those mystery fittings on the MC... you might have to get them from a junkyard unless someone here knows what size they are. One is larger than the other but if I'm remembering right, they both allow you to hook up a standard 3/16ths tube nut.
If you find out, let me know and I'll update page 1 of this thread. I've since switched over to a Ford Superduty master cylinder. No more Chevy parts :p
DanWheeler
DanWheeler
Kirkland, WA
Sorry, I missed this - I wanna say it was just a 1/2-13 die with 1/2-13 coupler, nuts and lock washers. It's kinda dangerous... probably better to weld it if you can. (I was just looking at my pictures of my superduty h-boost conversion and looks like I didn't weld that one either or even tack it so... do as I say not as I do :D)
Yeller
Rogers County Oklahoma
Yes the small reservoir is for the rear brakes. For the fittings I usually just replace the line and use a line and fitting kit like this, it gives you the fittings and new high quality line.
Line and fittings
And I use one of these to flare the lines.
Flare tool
Doing this cleans up the lines, gives you new lines and eliminates adapter fittings, fewer connections in your brake lines is a good thing, fewer connections equals less opportunity for a leak.
DanWheeler
DanWheeler
Kirkland, WA
Now I've fallen down the rabbit hole... I just went out and checked an Astro MC I have on the bench. My caliper's battery is dead, but it looks like the opening size of the front port is 1/2" and the rear port is 7/16"
This is interesting and confusing because the rear port, which is smaller, is closest to the larger reservoir which we believe goes to the front brakes.
And if you look closely, you can see that the size of the flare on the front port is also much bigger than the flare of the rear. A 3/16ths flared brake line would not fit properly on that front port. And you might say a 1/4" flared brake line would not fit properly on that rear port.
I found a picture (last one below) of a stock Astro MC which you can see uses a much larger tube for the front port than the rear. If I had to guess, that's 1/4" line on the front port and the rear is a 3/16ths. (unless it was metric at that point)
I have no idea what all this means... I thought the Astro vans had 4-wheel disc brakes so I assume both the front and rear ports go into an ABS module. Why is one tube bigger than the other? And does this challenge the assumption of the front vs rear port?
If the front port does go to the rear brakes, why would the tube be larger? You'd expect front disc brakes to need a larger tube vs rear drums.
Flare sizes are different for different size tubing (3/16ths line shown for scale)
y4m1mUOcN1jpQ-Jxc7Ym1uxLQWsVSsZJwq62lY-2o2dyJKUab61kvHXtxkjvYvH_KpXbAwbasQZpIT-cGYSsu0P_OF2moKdJFkavRveEGSOYHz4V1_8_CpPG0Gng6Ml_L_6E1F5X0EBzcdyvrqVj9OTWS00v2gKfPOKe4oBZrwIGenDwXxfj-dRP1E5YmP61s01
Astro MC reservoir (larger reservoir nearest rear port)
y4mLGp_FyDxkWtMnl0_JHbNq7hacOGPXsKIN6FJsuHHKEd1MNQoN9AXGMZz2IwohpM_p7GeFMOVWQle66MZDu2HWbpGU-YhtY1WadjvLJ1mjO9fxSpuztveJ61jlZwQhMfSU5HxoomUkMqlZhfkBztELObviTUo6BcNIFliyyFyVUzy3PlIOiI7SEv-dCZnT0HQ
Stock Astro Van MC showing different size tubes front vs rear (note smaller reservoir towards front)
y4mrvdkVmh-jhtH-o2VTRzUOiB7bv5ai9AU19kjQd72Uf8XbeA9UTp_noAPXefVkvtqXiLKtS6T-cXBQ8RXcDtFGOfsDLqeoPvxSXRe1ZEzJKUNFQbemIh5l3GLk_ZQ-OM2lgdSSyFksuoK3o4eFGV1CBdw72MAxltvbxO6M4Kx5kNZ_Zdk9uasbnOLiY3RKe2f
Why not just look in a shop manual for the donor vehicle to find out which reservoir is which?
Might not tell you the fitting size, but at least you can put the front-or-rear thing to bed.
Or if you’re going to the junkyard anyway you could just check how the factory plumbed it
I never noticed any correlation between the size of the port threaded fitting to any particular location. But that’s pretty easy to check as well. See if Ford or GM has always followed the same pattern.
toddz69
Flare tool
Well, that looks like a cool tool! Never have seen one of those. I have one of the Mastercool hydraulic ones but this one looks a lot tidier for on-the-vehicle work.
Todd Z.
