Explorer swap sensor confusion!!
C
charlien
Clarksville, TN
Hey viper...use a conversion factor of .5 (divide kg/hr in half) and convert the kg/hr to cfm and replot them if you don't mind...let's see what that looks like.
C
charlien
Clarksville, TN
------A9L ---- 94-95 Cobra ---- 94-95 GT
1V ---- 15cfm ---- 15cfm ---- 15cfm
2v ---- 50cfm ---- 50cfm ---- 50cfm
3v ---- 130cfm ---- 125cfm ---- 125cfm
4v ---- 265cfm ---- 255cfm ---- 255cfm
This is supposed to be a table....not much difference huh...
If it supposedly take 1.6 cfm to make 1 hp, and a stock motor is a little over 200hp, then you would only need 125cfm or 3V....and there is less than 4% difference at 3V between the A9l and 70mm 94-95 MAF.
Viperwolf1
electron whisperer
The chart would look exactly the same except the scale on the y axis would be halved.
lars
Been here awhile
NorCal flatlands
I have the Explorer 70mm transfer function on my computer at home. I'm using it with a Tweecer on my A9L. I'll try to overcome my ADD long enough to sit still when I get home and post it here.
As for the comment about surging with mismatched MAF & ECU, that was me, once. I couldn't get my engine (5.0 Explorer, orange top 19 lb injectors, etc) to run right with anything other than the Mustang 55mm MAF. Even with the Tweecer and the Explorer MAF I still had to do some MAF curve tuning to settle the idle- probably due to my non-stock cam.
lars
Been here awhile
NorCal flatlands
2000 Explorer MAF curve
As promised.
0 0
0.71338 10.777
0.83569 13.946
0.948 17.116
1.085 21.553
1.2021 25.991
1.4172 35.183
1.481 38.352
1.564 42.79
1.7205 51.982
1.8572 61.174
1.96 69.098
2.0771 78.29
2.1848 87.482
2.2629 95.089
2.439 113.16
2.5806 129.95
2.7175 148.02
2.8347 164.82
2.9424 181.62
3.0547 200.32
3.2405 234.55
3.5728 303.97
3.7585 346.76
3.9395 390.82
4.1006 434.56
4.3794 520.77
4.6287 608.25
5.0049 754.69
The 64 thousand dollar question is what units those are. I'll confess I didn't do my due diligence but the numbers should be scalable.
C
charlien
Clarksville, TN
I sent him a private message...............
Re: MAF question
Originally Posted by charlien
When you were having problems with your MAF...you said you were using the 70mm MAF to start..was this the explorer MAF or the 94-95 70mm MAF? and when you got a new one, you said it fixed your problems....what size/model was your new one?
All of this is from your running lean post.
Thanks,
Charlie
Over the last couple of years I've managed to collect enough EFI parts to convert three Broncos, so it is difficult to say where the MAF came from. I believe it is from a Cobra, I know it's not from the Explorer. This is the one that gave me problems with the A9L ecu.
I believe the new one is from a 92-93 mustang 5.0. Once this was installed, the lean conditions went away.
I hope this helps.
Brian
Viperwolf1
electron whisperer
As promised.
0 0
0.71338 10.777
0.83569 13.946
0.948 17.116
1.085 21.553
1.2021 25.991
1.4172 35.183
1.481 38.352
1.564 42.79
1.7205 51.982
1.8572 61.174
1.96 69.098
2.0771 78.29
2.1848 87.482
2.2629 95.089
2.439 113.16
2.5806 129.95
Assuming those are cfm numbers, this is the comparison.
If they are Kg/hr numbers look at the 2nd chart (maf3.jpg).
Charts are updated. I think it's clear those are Kg/hr numbers so the 2nd chart is correct.
C
charlien
Clarksville, TN
Can you really compare those numbers, since the computers were matched to the MAF and they all used different computers??????
I think the proof is there...both Stretch and Lars tried the larger MAF sensors and they didn't work (without a custom tune in Lars' case).
I guess the real question is, Has anyone used the larger MAFs and had it work?????
Viperwolf1
electron whisperer
I think the moral of this story is, if you're using a A9* ECM a '94-'95 mustang MAF is more likely to give you better results than an explorer MAF.
If stretch was using a '94-'95 mustang MAF that's only one data point.
Viperwolf1
electron whisperer
Viper....."If stretch was using a '94-'95 mustang MAF that's only one data point"
I'm not sure what you mean by this?
I mean you're right, we need more people to fess up and let us know if they've tried it. For all we know stretch's MAF could have been damaged.
lars
Been here awhile
NorCal flatlands
I should point out that I grabbed that data from the Tweecer (caledit) software which is known to suck. I find it odd that the curve stops at 2.58 volts. Clint Garrity's software is infinitely superior to the bug-laden product supplied by Mike Glover of Tweecer fame, and it may well be that there is a scaling factor error in the numbers I posted (there definitely is in the software). Which reminds me that it's time to get off my arse and finish my tuning. But first, must... finish... airplane... project...
lars
Been here awhile
NorCal flatlands
OK, it's me that sucks. I failed to notice the curve points past 2.5807 volts, which were hidden in plain sight in Caledit. I added the values to my earlier post.
That updated chart really shows the difference of the Explorer MAF compared to the mustang MAFs. Don't have the time at the moment to really analyse it, but with the mustangs having a spread of 8% (from prior math) That Explorer has to be WAY different.
