Explorer swap - what to level?
1buckeyefan1
So I finally got my engine and Trans in. A little surprised at how much higher it sits vs the stock c4...but I suspect it's because the bc cross member sits low for the exhaust to route above. The bc bronco cross member isn't quick bolt-in, looks like I need to drill another set of holes in it. I knew I had to make a spacer for the 4r70w awd tailpiece, but was told that it should only be an inch or so.
So I've checked other threads and they've leveled the Trans pan.. however it sort of feels like I should level based on the lower intake? At least that appears to be "more level" to the eye. that and it makes the 4r70w mounting flange level too.
If I level to the intake, i have about a 4" gap to make up. The engine "looks" level, but the trans pan is not.
If I level to the trans pan, I have a 1.5" gap to make up and I can *barely* catch the tail end of the mounting holes. This seems right, but odd that the 4r70w mounting flange is not parallel to the crossmember, which leaves the trans mounting pad not quite square. But if I mount with the trans pan level, it seems that it has to be this way?
Hazegray
The motor is normally set at 3 degrees towards the rear. That might help you...
1buckeyefan1
1buckeyefan1
Grab a cheap digital degree angle finder it will make things a lot easier. Also check you driveshaft angle at the same time. That may give you a better ending measurement to make the geometry work in your favor.
https://www.amazon.com/Wixey-WR300-...er&qid=1616380293&sprefix=degree+angle&sr=8-8
All excellent advice! My protractor disappeared yesterday, so a perfect excuse to pickup a digital one. Also, great advice on checking the driveshaft at the same time. I'll post back w/ my numbers once the prime truck arrives!
pcf_mark
As other posters noted the engine angle is a result of the driveshaft angle needed for your rear axle. Get that right the engine ends up where it ends up. Unless your rear is at some funky angle and it needs shims. I put mine up nice and high for good ground clearance and hosed the angle. Now I need to lower it!
1buckeyefan1
1buckeyefan1
As other posters noted the engine angle is a result of the driveshaft angle needed for your rear axle. Get that right the engine ends up where it ends up. !
All good advice. per everyone's advice, I read up on past threads, tech articles and put a digital angle gauge on everything tonight and started bringing it up and down.
First up was trans pan at level:
- trans pan: 0.1 deg
- lower intake: 5.3 deg
- rear shaft (centered dowel for now until it gets cut): 17.4 deg
- angle @ dana20 output: 5.2 deg
- center section: 11.3 deg
With the trans pan level, the distance gap from cross member was approx 2. However, my next big problem is that the front output shaft is running right into the BC crossmember. I suspect i'm encountering the same thing Chuzie did by using the JBFab recommended 3rd clocking hole (vs the middle) and will have to clock the ZF bracket up to the middle and re-fab the twin stick bracket to even come close to clearing the BC Crossmember. Worst case, I have to fab up a custom crossmember. I'm also going to call Jason @ BC tomorrow to get his take.
1buckeyefan1
1buckeyefan1
Next up was the trans pan up +1 degree:
- driveshaft: 18.5 deg
- lower intake: 3.4 deg
- rear of d20: 3.2 deg
I obviously gave myself more clearance over the BC cross member with a +1 degree on the trans pan, but picked up another degree on my driveshaft, making my pinion angle worse.
The other complication is that my idler pulley is now touching my front crossmember with the trans pan +1 degree.
1buckeyefan1
1buckeyefan1
So as I read more tech articles and consult my 7th grade daughter for geometry tutelage, I hope others w/ more experience can chime in on 'what is right' for the rear driveshaft?
Some variables I need to consider:
- I need to get my driveshafts built yet.. but really need to get the body on first before I measure. I think my 'centered dowel' method is quasi-scientific for now?
- I need to clear the BC crossmember, or throw in the towel and fab up a custom one. It's pretty much a foregone conclusion that I need to ditch the JBFab twin stick bracket and go back to the middle clocking position to gain myself a little more clearance. Ideally, i would figure out how to measure it weighted w/out the body, order the Woods driveshafts and raise the trans up enough to clear the crossmember.. but I don't think i'm ready to order driveshafts yet?
- I can use the smaller idler pulley upfront if I need the extra clearance in the rear
- Do I need to shim the rear axle to make up for anything?
- does 1 degree of pinion angle difference make any difference at this point? What would y'all consider getting the rear driveshaft 'right' at this point?
btw - i am not running any suspension lift at this point. Replacement height springs and shocks. I'm pretty sure I have the rear springs in correctly as well?? is an 11.3 degree angle normal for a 'stock' 3rd member?
pcf_mark
Since you do not have the body on to fully load the chassis I think you are going to have to wait to finalize your driveline angle. The angle of pinion will change when fully loaded and you are trying to hit a 1 1 1/2 degree window.
1buckeyefan1
1buckeyefan1
Yep. The more I read up on past threads like this one, it sounds like the original engine angle was 4.75". So I'm not as worried about that as much as when I first posted.
Re: loading for my pinion angle.. that really makes sense. As the leaf springs compress, the axle will likely rotate (probably for the worse). What baffles me yet is that I'm using (what i think) is a stock axle & springs w/ no lift.. I can't figure out why my pinion angle is 6 degrees. Lifting the transmission up only makes it worse at this point. Lowering it gives me no room to clear the transmission mount.
So I think my strategy now is to move the AA/ZF adapter clocking position back to the middle, call JB for a new twin stick bracket, then attach my front driveshaft and lift the transmission up to the point that it clears the crossmember. If that doesn't work, it looks like I will need to ditch the BC crossmember and fab up something new.
Then once I get the body on, driveshafts in, etc.. I can measure the pinion angle again. I don't think I will ever hit 1.5 degrees though...and it seems counterintuitive to add shims on a stock suspension? But if I use a spacer in the trans lift, I suppose I can unbolt it and adjust as needed, or add shims on the rear axle. Unsure if there are any other variables I can adjust beyond those 2.
1buckeyefan1
1buckeyefan1
I also hit the same wall that Chuzie did with the ZF adapter clocked to the 'last' position in order to make the JBFab twin stick bracket to fit properly. But now my front output shaft of the D20 runs smack into the BC crossmember. I'm pretty sure i'm going to need to go back to the middle clocking position as Chuzie also did and hack up the JBFab bracket and try to make it work and gain the clearance needed for the BC crossmember.
Update: I spoke w/ Jon at JBFab.. he's seen this many times through the years. Turns out that the 'arm' adapter that his twin sticks shoulder bolt mounts to is not correct...but Advance Adapters makes this, not him. Unmodified, it will only work on the 3rd clocking position. Per his advice, I called Steve at Advance Adapters and he confirmed as well.. it was built for the 3rd clocking position and never revised. So now I have to grind out the weld/webbing, leave a little bit to use as a hinge and weld it back into a more upright position so I can go back to the middle clocking position. This should give me at least an inch or two clearance over the crossmember. I'll update more once I finish this.
As everyone warned me.. there is no out of the box / bolt together solution for this :)
jmhend
One other option is to try to sbim you motor mounts up a little or but the Extreme/ HD ones from one of the vendors (this is one of the options I added to .y explorer motor (yet to be installed)).
The HD motor mounts will raise your engine about 1-1/2" (I think). This may help your idler pulley but it may also mess up your other numbers.
I hope this helps a little. I see your getting your moneys worth with that angle finder...
Sent from my SM-N960U using Tapatalk
1buckeyefan1
1buckeyefan1
Yep, the angle finder was a great recommendation! I was using old-school protractors and levels. This is way easier..
I did consider the HD motor mounts...but was holding back on that option after I exhaust all others. Mainly b/c I don't want to run into hood clearance issues with the intake, etc...even though I'll be running a 2" body lift. I already got a lowered coil pack, plan to drop the PS reservoir,etc. Also, i was afraid of bringing the engine up even further, then having to shim the rear axle to adjust for greater pinion angle, etc. But it's good to have that as another variable if needed.
I also spoke w/ Jason at BC about the crossmember. He says they put the engines in with a 5 degree drop and vary between a .5 to 1.5" spacer on the crossmember. I'm at 5 degree with a 1.5" spacer, so it sounds like it's going to be close to what they do.
I'm going to re-clock the ZF adapter and start cutting up my twin stick bracket tonight. Crossing my fingers that I'll clear the crossmember with my front driveshaft :)
jmhend
Understood, just putting it out there.
1buckeyefan1
1buckeyefan1
Thanks! I really appreciate the responses and ideas.. I couldn't imagine undertaking this swap w/out the support of this forum.
So I ended up re-clocking the ZF adapter to the middle - this just barely nets me the clearance I need to get my driveshaft across the BC crossmember.
I had to cut up the AA Twin Stick bracket.. so sad, as it was nice and powdercoated already. I ended up moving it over .5" and up about .75". I applied some amateur welds and it seems to be holding in place.
I also placed a 1.5" square tube spacer between the 4r70w tail housing and the BC trans rubber pad. This seemed to net me a 4.7 degree angle on the top of the intake, which seems inline with what Jason @ BC told me they do with theirs and it's close to the original angle of the stock 302?
I think this leaves me with approx 6 degrees of pinion angle in the rear. I'm going to wait and check it again when I get my body eventually put back on and then decide to shim, etc.
I think i'm good for now? thanks to all for your help!
I see one other area of importance that unfortunately you can't take for granted when setting the angles. And that you can't factor in because your body is not installed. That's the lack of clearance between the back of the driver's side cylinder head and the firewall.
Given the numbers you've been using, you're probably ok because others have used them successfully. I only bring it up because it's such a tight clearance you don't have room for a mistake here.
Not sure how best to check that before the body is on, but there should be a way.
Regarding the driveshaft and rear pinion angles, don't do a thing until you're sure the suspension is compressed to the expected ride height. Right now you can NOT assume it should be sitting there because there is zero weight on the frame other than the engine and gearboxes. And that's not enough. Even a tired old original set of springs will extend upward when you remove the body. Heck, just removing the hard top is enough to get a rake out of some Broncos.
And even though there is no etched-in-stone exact measurement you can get, we've been using 6" between the top of the axle tube and the bottom of the frame rail for a generalization for the stock height of the rear suspension. Front is 7" so one inch more, but for your uses you need to get to that 6" measurement at the rear.
Adding weight, or using ratchet straps or come-a-longs to compress the suspension is what you need to do until you can get the body added on, in addition to all the normal weight a Bronco carries in stock form.
Then and only then will you be able to verify the proper angle of the rear end and measure for driveshaft length to your new, longer transmission/drivetrain setup.
There is no go-to angle that the rear end must be at once you've customized so much. Each vehicle can vary by even a small amount, which could be enough to ruin your day once you get it out on the road.
Once your engine and trans are at the proper angle you want, and the suspension is compressed, then you mock up a driveshaft to see what, if any changes you need to make to the rear end angle. Which should be 1-2 degrees below the centerline of your driveshaft. At ride height...
Once there, you can measure for length of the driveshaft.
