I respectfully disagree...The stock explorer 5.0 manifolds are very restrictive, plus dump straight down not sure if they would hit the frame rail or not.
I believe there are better options from the vendors that are not that much money
The 96 tubular exhaust manifolds are restrictive. There is probably some restrictions in using the later P-heads cast iron manifolds (plus having to use a metric oil drain plug to plug the EGR supply port if not retaining EGR). But considering the options out there, such as the Sanderson headers once sold by Bronco Hut (which were pricey), they are a viable option.
Since he has a 2000 motor, then it will have p-heads, he can use the factory manifolds, do some grinding on the stock Bronco manifolds, or something aftermarket.
The Drivers side dumps downward and there is minimal interference. (It has been a while since I did a manual Trans swap, but don't recall an issue) Passenger side is a little different. It kicks backward and it is tight fit with the frame and cooling lines for the 4R70W. (I use the Explorer 3/8 lines and put a heat wrap on them) Having the trans dipstick tube in the vicinity also makes things tight. My local exhaust shops have had good success in building a system that fits. It is helpful to keep the first couple of inches of the factory Explorer exhaust pipe, with the flanges.
I have done 5 Explorer swaps, while I don't claim to be an expert, I will say that I have had some experience...
I will say that it is a night and day difference when you remove a factory Bronco smog/carburetor motor and replace it with a stock Explorer EFI motor, even if you retain the cast iron manifolds with a single exhexhaust
1996-2001What’s the last year for the explorer 5.0 ?
I saw a cheap V8 explorer for sale near me , ($900) was a 4wd . Not sure if that makes the swap easier or harder .
I will say that it is a night and day difference when you remove a factory Bronco smog/carburetor motor and replace it with a stock Explorer EFI motor, even if you retain the cast iron manifolds with a single exhaust.
I'm wondering if it is worth going with the Sanderson headers over stock manifolds? The big issues is EGR, if I dont use the stock manifolds I will have a check engine light. But is that an ok trade off for the Sanderson headers???? ThanksI respectfully disagree...
