Remove the driveshaft is the safe way to do it.
Many people have had thousands of trouble free miles leaving the trans in top gear and tossing the transfer case in neutral. Some tips that can help...
Lock in the front hubs. Why? That spins the front output gear and that helps splash around gear oil enough to get that rear output bearing.
There have been people who add elbows to the fill point to raise the oil level enough that it is up to that rear bearing.
At the very least drive around before towing, splash some fresh oil onto the bearings and hope it is enough to last the trip. Don't grab a Bronco that has been sitting in a field for a decade, kick the transfer case in neutral and go flat towing with bearing that have been drip drying forever.
But dropping the driveshaft will still be the least drag and the safest on parts.
As for brakes? That can be sketchy. The lighter the tow vehicle, the sketchier. But I am sure I have seen scektchier stuff. Watched someone tow a car down the highway without a tow bar. Just a chain and ran it through a pipe so it wouldn't rear end him when he slowed down. You pass him and look and think to yourself "what did I just see?"
There was another one, that I pulled over, got out my phone (phone cameras didn't exist in the one above) and snapped a picture of this a couple years ago on I8 in California. Going to say nothing behind that Tahoe had any brakes at all. Just in case you don't understand what you are looking at, the Jeep on the single axle trailer is being pulled by the Grand Cherokee and said Grand Cherokee is being flat towed by a Tahoe. East bound and down...
