Passenger side is put back together. Took about 3 hours to degrease everything, spindle, axle, hub parts, and get it all put back together.
Couple of things to be aware of:
1. there is no inner axle seal on the end of the axle tube, i.e. where the axle exits the tube, not the differential side. There is a slinger which is supposed to keep large debris out. Many people will remove these since they also keep in whatever does get past them. Since there is an axle seal where the axle enters the differential housing, it isn't a big deal if you have the slinger or not.
2. When reassembling the hub, use a prybar or screwdriver against the axle u-joint area to press the axle outward in order to get the snapring onto the end of the axle shaft.
3. Assembly order is brake backing plate, dust shield, spindle
4. There are two different sized bearings that go behind the hub. The big one should slide all the way down onto the spindle.
5. There is no seal behind the spindle bearing. The seals on the outer axle shaft seal this area.
If I have to do this again, I think I will pull the whole axle and work on it standing up, instead of on a creeper under the bronco.
