I'm a don't-fear-the-gear adherent myself, but think that the same 4.56's I use with the 31's would still be fine for your 35's.
I have a friend with a Mustang 5.0 (stock) in his '77 with NV4500 manual trans and runs BFG 35's on the street with the stock 4.11 gears. Runs about 2100 at 65.
He does have to shift out of fifth on the really steep hills, but not immediately.
However it would be more peppy with 4.56's and not lose it's drive-ability or fuel economy I'd bet. Might even improve the economy in fact.
Heck, I can get 20mpg with the 4.56's and 31's (actual 29.5" rolling diameter) tires if I keep the speed down. Runs about 2300 to 2400 at 65.
With 35's that combo would be less off-road friendly (2050rpm or so at 65), but you've already stated no wheeling in your future.
So while I don't think you would need the 5.13 choice in your particular case, don't go taller than 4.56 either. As said, keep it above 2000 rpm even with a finely tuned Explorer motor and you'll be happier with the performance. After all, you didn't put all this money and time into the conversion to have a dog. Right?
A 4.88 set would put you at closer to 2200 rpm at 65mph. Probably the better choice, given that the larger tire also is harder for the engine to turn, and the higher stance makes aerodynamics even more of an issue.
The friend of yours was talking about the Dana axles. The lower you go (higher numerically) with the gears, the smaller the pinion gear gets. This makes lower gearing and bigger tires a weaker proposition for the front.
But only in 4wd. So again, not an issue for you.
