I'm tired of smelling gasoline in my garage and thinking of adding a charcoal canister. I've googled the forum and found these two helpful links:
https://classicbroncos.com/forums/threads/charcoal-canister-installation.261451/
https://classicbroncos.com/forums/threads/where-should-the-charcoal-canister-be-mounted.218039/
Specifics on the rig: 1972 U15 with 1992 Mustang 5.0 EFI / AOD swap, currently no charcoal canister and BCB 24 gallon tank.
General thoughts: I'm thinking of following the approach that xcntrk did on first link above and evacuating the canister prior to MAF.
Basic questions:
1. I assume one needs to use non-vented gas tank cap on this approach?
2. There are four fittings on charcoal canister. The two large ones obviously get the caps, then also is a small fitting and a medium fitting. Does small fitting or medium fitting go to MAF?
3. How does the tank get backfill of air as the gasoline is consumed? Is there another connection needed to tank. Maybe with check valve to allow air to get into tank but not allow gasoline fumes to migrate out?
Thanks in advance for advice or any links that already address the above questions.
Basic questions:
