My 1971 Baja Bronco
coachbarnes
Franktown/Breck, CO
Did you replace the coil springs AND leafs? If so, which one's did you use and how's the ride? I'm going thru a similar process w/a '74 Baja that I also got from Andrew. Just trying to make the ride a little more old man friendly! ;D -- funny, I'm going from 350's to 411's though since mine came w/411's. We should have just swapped R&P's! haha...
BajaBronco
I'll chime in, since I just saw this - We did Bilsteins all around, originally x4 but found the x8 is best for the springs we chose. Did WH in the rear and progressive rate front, all stock height. Youll need different part numbers for almost all the parts due to length. But I'd probably recommend springs from WH front and rear for your 74.
coachbarnes
Franktown/Breck, CO
Thanks Andrew -- What do you mean different part numbers?
BajaBronco
We did stock height on Andy's Bronco, and I just figured youd do a 2.5 lift or so. But I can set you up with the parts if you want stock height!
Andrew
markw
Andrew and Andy, what do you use to get that adhesive off? And leave the paint. Thanks, Mark
andyp
andyp
Front seats back in. Don't like the repop hinge cover color. Need to paint them.
Did some painting.
Had a nice trip to the snow, definitely the oldest truck in the lot...
House
Minutia Militia
Looks great Andy!
In that pic the hinge cover doesn't look too far off from the seatbelt cover color...?
andyp
andyp
That seat belt cover is trashed and not cleanable. That is just dirt and age.
Need new ones.
miikee73
Shadetree Guru
Aloha
Did some painting.
And probably had a lot of attention. I can hear it now, Did you see that Jeep over there....LOL
andyp
andyp
Looks good. What risers and crossbar are you using for the ski rack? (Part #'s if you have them).
I was in a hurry so I bought new feet. Thule 300 Rain Gutter Foot pack. Bought used cross bars.
andyp
andyp
Amazingly a guy came up to me who knew exactly what the truck was and had owned one. He said he traded it for 65 Mustang fastback and still owns the fastback.
People were stunned that we would drive an old truck 175 miles in the winter.
904Bronco
San Martin, CA
Great picture... Might be calendar worthy!
andyp
andyp
In my continuing quest to make this truck a better driver I ordered an Impact series rear bumper and tire carrier. The stock carrier just makes to much noise for me. We shall see how it looks on the truck.
englewoodcowboy
Lick Creek Restorations
Have you tried rebuilding the stock carrier, bushings etc? I know they will always make a little noise but some I have seen have been very firm and appeared decent though I had no time in them to see how they did rattle wise. Great looking Bronco BTW... a Stroppe is on my bucket list...
andyp
andyp
No I have not. The bracket that holds the carrier is the main issue. I don't think it was ever designed to hold the size tires we are running now.
It's actually bending the body slightly. I need to get that fixed.
