My second Bronco... Crawler build...
Monster Mike
That's what I was thinking;D
X2! ;D
Stock doors and trail doors. Do ur own hinge mods cheap ass ;) orrrrr play it smart and get the duff trail doors with all the hinges for $399
Sorry taking so long for getting back to you, I was in the hospital from my head exploding
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
X2! ;D
I thought I heard a dull thud from across the country!! ;D;D
It must be nice to have your kind of money... Suzy's doors are nice, but i still have too many other things I need to go out and spend that kind of dough on non-necessities. Thats what I will be doing next summer after I get this pig out of the garage!
englewoodcowboy
Lick Creek Restorations
Going big and even dancing with the threshold of too BIG is OK so long as it is not an attempt to compensate for other things that are not. :)
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Since the floors are finally done, I mounted the body back to the frame and started cutting the rockers.
The passenger rocker had some rot, but was really salvageable. The drivers side is toast. Both were full of old mud and sand...
Where I started- you can see a little rot.
And after I cut it...
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Went round and round trying to figure out some trick rock skis, but ended up doing some pretty standard type. I had 2x2x 1/4 and some 1.75" 0.210 wall DOM. I wasn't sure the JD2 model 32 would handle the thick tube, but it did well. I folded over the sheet metal under the door and will weld the rockers right to it.
With some luck I will get to the drivers side tonight. I think they turned out alright and are stout!
SC74
You'll be glad you went with the thicker tubing. I used .120 wall and they look like popcorn on the bottoms. But... I'm not easy on my junk either ;D
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
I remember you telling me that at the Super Cel this year. I had it laying around and wasn't even sure I could bend it... Now I'm looking at using the other stick for primary bumper parts.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
I just realized its been right at one year last week that I have been on this project... I recall foolishly thinking I could have this thing on the trail in one year...
I am nowhere near having this thing running never mind actually being on the trail. I just hope I am not making a similar post in June of 2015... The only things slowing me down are money and time. Isn't that the story of life!
97XEB
Love the build. My opinion on the doors? Skip the inserts. Run the doors with the James Duff removable hinges. It's the most versatile option, and best of all Worlds.
I just bought the James Duff hinges this weekend at the Roundup. Let me tell you they are worth every penny! SUPER STOUT construction. 1/2" hinge pins. Makes taking the doors off and putting them back on a breeze - easy one man job. I'm also confident they would hold up to trail abuse should you catch one.
I didn't do the "stock mod" (cut and flip) because it would have messed up my paint lines and in case I ever want to go back to my original / more stock look. Yes, the Duff hinges are pricey, but they make the stock hinges look like toys, and they are still much more economical than the SS options.
Hope that helps.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Great input- thanks. My concern with the hinges sticking out- they are out there to catch rocks and trees. While this will never be as pretty as the Monster Bronco, I want to try to keep the door pillars intact as they form the basic structure of the body.
If I keep doors, I may go this way...
97XEB
Thanks. They do stick out, but again, they are STOUT. I haven't wheeled with them yet, but if you plan on regularly sliding your body against trees and rocks you have a valid concern - unless you make a "slider bar" for the fenders that clears them.
I just love the versatility. Doors on when it rains, is cold or when you just want to button things up. Doors off for most wheeling and in the nice weather... Couldn't be easier to switch between the two.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
I currently have no provisions for heat and since the bed is dovetailed- I will have no top other than a bikini top... If it rains- I better have rain gear!! I like the look of the doors and they will keep some mud and dirt off the occupants, but they are really only another panel to get wrinkles in. If the doors were any good, I would sell them, but the have been hacked up and bondo'd by a PO, so I figure I would throw them on.
97XEB
Got it... I agree with the look of the doors, and the function in terms of keeping trail debris off passengers. In that case, just do the mod to the stock hinges - though it might still be a good idea to replace the hinge bushings. I didn't realize how SHOT mine where until I got them off to replace em. Good luck. I'll keep checking in for updates.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Had the day off today and spent most of it working on the crawler. Most of it on little stuff. Worked on the body where I narrowed it...
Worked on the front winch mount and then grille/body mounts...
Finally. cycled the front suspension with the coilovers in... And found a problem. This pic is of the steering at full stuff just short of full lock. Not sure what to do here. I have about 1/4" clearance to the frame when fully extended, so this is a little bit of a predicament.
tasker
all knowing of nothing
NH
Winch? Why would you ever need one on that??
