My second Bronco... Crawler build...
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Todd just for some comfort i've got some tire into the springs in the rear, when fully flexed out, and it does flex bigtime, got lucky not to bend the shock rod;) as long as i'm crawling! I will definently be movoing the tabs once again---but not now, the speed in testing the rigs ability will surely tell me when i have to do it---or when i break a shock:(;D
See now... No ones perfect! ;D
I have seen a lot of paint rub off springs, but never seen a shock bend with a tire rubbing on it. Now when it rubs the frame...
I have some other minor alterations to fix as well... Thought I cut the fenders enough and I have to go a little further forward... Which wouldn't be bad if I had spent time getting them nice...
Getting tired of grinding dust!!
Letsgocrawling
Tucson Az.
Yah tell me about it, that's where the brain damage becomes a reality for me. We are our own critic--as i see you are as anal as me;D---but i guess that's a good thing:-X;D perfect---what the hell is that:cool: cool, i can relate to that;)
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Got a little progress this weekend. Got the front bumper mostly done. I am planning to finish the front body and hood then getting on the motor...
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Yes the fairlead is offset- the winch body is not symmetric and to sink it under the headlights, I had to offset it. I don't like how the fair lead ended up so low, but I will eventually go to synthetic rope and a hawse fairlead. Down the road I will also put some sort of hoops out around the headlights.
Letsgocrawling
Tucson Az.
krikee that is low maybe you ought to step up to some 33"s ;D Todd, just keep going forget the short chit ok mister:cool:
Monster Mike
I'm already day dreaming of our rigs going out wheeling together todd! but first me and marky Mark (lets go crawling) are gonna do some sand racing in august :cool:
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Yeah Mark... Low is a relative term, but when crawling over VW bug sized boulders... It is a little exposed.
For reference... I put it back on the tires this evening.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Got my Artec fuel tank mount in and picked up a wiper motor bracket and 351w dizzy off here... Ready to get the motor rebuild moving. That's about all at the moment.
It is nice having a rig with an 8274 mounted to it. Made short work of pulling my 5000lb Dodge onto the trailer. Dead pull and the winch never even groaned!!
And yes- my neighbors love me!!
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Been a month since my last update... Still pulling parts off the Dodge- and although the wife has been patient, sh is starting to drop hints about the truck sitting on a trailer in the driveway!
I have been only working on the engine as I need to drop it in to check clearances.
351W- I am going to leave the bottom end stock- it has 80k on it and I heard it running strong before I bought it. The bores look good, bearings look good, so I am leaving it alone and hoping it doesn't bite me in the ass down the road.
Like a kid I am waiting on a few parts to arrive today; COmp Cams XE266HR cam with matching valve springs like what I have in my 347, new timing set, and all new ARP hardware for the top end.
Should look good with the BC Broncos shorty headers, Weind Stealth intake and Holley Avenger fuel injection as well as the AFR165 heads and roller rockers I got for free with this rig.
I figure it will have plenty of power for a warmed stock bore motor and I like the power from my 347. Pics to follow after the weekend.
tasker
all knowing of nothing
NH
SHOULD of started with the 351 in the other one too %)
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Had too much stuff for the 302 base and I really like the 347.
I bought the crawler with a 351w, but it was beat. I was able to salvage the intake and a few other misc items and got a good 351efi for a fair price.
tasker
NH
JUST bustin Todd....we need to get these rigs done!
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
No problems my friend. Got to have the ball busters to keep you moving. I have been jumping back and forth to different parts to get stuff done.
I think I have chosen a color... I really like the Chrome Yellow- in certain pics. In some it looks orangy and in others it looks too yellow.
This is the color I want...
But alot of pics I see it looks like this...
Am I just too picky or is it the angle with the light? I really like the orangy yellow. To try it out, I bought a can of dupli-color chrome yellow and sprayed it on some sheetmetal and it is not at all orangy... I dont think it is the correct 81353 PPG Chrome Yellow- which I have seen called School Bus Yellow...
(Sorry if I have used a pic of your Bronco- these are just found on the web)
allenfahey
If you get me a good paint code ill make a spray out card of it and mail it to you.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Some progress on the engine today. I needed to get it in the truck to mock up room for everything under the hood.
Specs:
351w stock bottom end
Comp Cams XE266HR cam
Scorpion 1.6 roller rockers
Roller lifters
AFR165 heads with Comp matched springs
Weind Stealth Intake
Holley Avenger EFi
MSD billet Dizzy
BC Broncos headers
All new gaskets, rear main, oil pump, timing chain, etc. mostly ARP fastener too. Still needs correct length push rods and valve covers.
