My second Bronco... Crawler build...
xfalcon
No problems my friend. Got to have the ball busters to keep you moving. I have been jumping back and forth to different parts to get stuff done.
I think I have chosen a color... I really like the Chrome Yellow- in certain pics. In some it looks orangy and in others it looks too yellow.
This is the color I want...
QUOTE]
Always liked that color and that Bronco, it will look Great;D
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Definitely going to require some hood mods... If I wanted to cut the factory motor mounts off the frame, I could drop the engine about an inch or so. Too much work for so little gain.
fatboy
Glad to be here.
New Hampshire
Well you already have to "narrow" the hood, so what's a little more work! ;D
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Progress has been really slow... motivation is hard to come by...
I put the trans mission in and started mounting the T-cases- I will have to notch the frame considerably to clear he second case. Good news is that it looks like I will have good length and angle on the rear driveshaft...
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Notched the frame and got the cases mocked in... I am planning a slip yoke eliminator on the rear case. Front shaft is really long...
Frame is supported by the subframe and rock sliders, so no concerns about hacking the frame!
Big hole in the frame- will be boxed in.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Tcase in! I am going to clock it one more hole to get it completely flat belly. Notch should be big enough.
Don't mind the funky angle on the subframe... I dropped the front of the truck to get trans in.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Drivetrain is a warmed 351w with a C6, NP231 range box, box4rox doubler and NP241. Low range is 7.5:1, coupled with the C6 and 5.38 gears- I will have 100:1 crawl ratio. Same as I ran in my Dodge with the 44s and it just worked!
Maybe the C6 will outlast the 46RH I had in the Dodge that had been rebuilt 3 times...
SC74
Looking good Todd! You did what I wish I had done, and still may do one day with my Atlas. If I notched my frame I could gain some belly height. Keep the pics coming!
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Thanks Robert.
I knew I was going to do a subframe of sorts for the suspension and bellypan, but it was a SWAG as I didnt have all the stuff to get it under the truck and mock it up until now. Measure 5 bajillion times and cut once- I am lucky it worked out! :cool:
It will have similar ground clearance to my old Dodge when done. I based alot off of that rig just cuz I liked the way it worked. I was also trying to keep this one lower- first to fit in the garage and second to keep the COG low.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Todd that is really coming along nicely.
Thanks Pete, I have a long way to go, but getting the drivetrain in was motivational... even if it all has to come out again!
This will allow me to get the trans/tcase cross-members set, the shook hoop crossover as well as hydro steering and hydroboost placement set.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Scrapped my Dodge finally this weekend... I have had this truck for 20 years. A lot of memories...
Cab frame and engine were only worth $300 in scrap...
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Got a little bit of work done on the crawler. I put the front coilovers in with the springs from my Dodge- 300/450 is just way too much for this crawler. It's 3-4" too tall in this pic and the coilovers are adjusted all the way in.
Started working on the shifters from the doubler. These are a pair of stock Dodge shifters I modified for my old crawler. I will cut them down and I moved them a little more to the center.
