joe
- Sep 9, 2001
- 1,932
A Few from OCBR 2015
two sweet rides right their
6X roll was Dennis with LEBC. I don't think his was a BB cage, but it held up pretty well too. He rolled OVER his son-in-law's Bronco that was below him on the hill. The other roll was Adam's (also with LEBC) dad who slow rolled on Rubicon - lots of damage to the front clip sheet metal but cage looked great. (Possibly the other BB?) Sorry I don't have pics of either.
I had problems with fuel delivery on my FITECH EFI system. After being pulled back to the pavilion 3 times by Alan Stark (Thank Goodness for him), I'm running their EFI system with the Command Center, (remote sump tank fed by my mechanical pump) Runs fine on the street, but basically first trip out on the trails ran great for about 30 minutes and acted like my fuel pump died or ran out of fuel, got towed in, got it back running, and basically the same thing happened, actually burned up the high pressure fuel pump, replaced that, then still acted like it was running out of fuel on the trail, no fuel coming from stock mechanical pump, so I replaced that. Still died on trail, Ran great all over town. FITECH Support was great, even got to talk to the Designer of the Command Center. So after replacing one high pressure pump, one low pressure pump and talking to FITECH support, Ken, who designed the Command Center suggested that I disable the ROLLOVER Check Valve in the Command Center, that fixed it. So the problem was the machining tolerances were so tight that when pressure built up in the Command Center the vapors were pushing the check ball closed, causing all the problems. They had already had that problem and made a design change. They are replacing my fuel pump and the Command Center under warranty. So its all good, gave them some free R&D I guess. After disabling that check valve the system ran flawlessly on all types of terrain.
Sounds good! I have to stick to the 1-2's. I did some 3's that were kind of questionable for me. But I survived without a scratch!
Here's a few from my phone. Got some better ones coming later...
Nice to meet you young lady. Hope you had a great/safe trip home without too much incident.
Oh my Bronco loves the highway...just not inclines apparently. I ended up putting 800+ miles on it this weekend and got it home in one piece ;D
