Overheat Advise
mattt
Do you have any other radiator you could drop in there as a test?
jcb9089
jcb9089
this is my second radiator, bought the high efficiency radiator from JBG to replace stock style aluminum radiator with no help.
Well, to try to find out if it's a simple air flow issue, would you have an objection to trying the old trail-fix trick of removing the hood temporarily? Many a crawler Bronco used to be sighted on the trails around here sporting it's hood on it's roll cage!
I can't really imagine an air issue, with both a mechanical puller and electric pusher fans trying to get that cooling air through the core, but hey, stranger things have been discovered on Broncos!
And to refresh here (so I don't have to read through the whole thing again please!), what damper, pointer and block combination is this? If it's an Explorer block and Explorer front drive setup, then there's probably no question about the timing marks being accurate. But for any Franken-combination of dampers, front covers, pointers and cranks, it's very possible with Fords to get mixed signals
I may re-read the thread anyway, just to catch back up (been getting skewed memory banks lately), but that info would be helpful anyway.
If it's just the stock '75 stuff right down to the damper, then it's also likely correct, unless the pointer has been changed or the damper is old and has spun.
jcb9089
jcb9089
Thanks Paul,
It's a 76 block that's been rebuilt and has new harmonic balancer. Instead of running carbd, before I ever fired up, switched to EFI, GT40 intake, 65 mm TB, 19lb injectors matched to MAF.
I checked compression and it's great, no vac leaks.
From the way it acts, would assume a vac leak, but it holds solid vac um.
No ecm codes that point to out of the ordinary conditions. Fires right up and idles, but can not hold temp at Idle. When I drive, it cools down, but heats right up to 230 at idle.
Multiple temp gauges with same result.
Also swapped out MAF, but no love.
If you have not already then, I would verify that your timing marks and actual TDC are on the same page. Ford used at least three different timing mark locations on our engines over the years. With the appropriate pointer, this is not an issue. But with a new damper that just happens to be for another application, your marks could be way off.
I'm guessing this is not fully off however, or I would think your engine would not run right and may even set a code. But you can't take anything for granted these days.
To my mind, it's worth the verification process. Then, if it's determined to be off, use timing tape to re-orient the marks to match your pointer.
ntsqd
heratic car camper
Upper SoKA
Water pump drive ratio?
Still the clutch fan as in the first pic?
Does the temp start to drop if you raise it off idle?
Other than driving it, what does have a cooling effect on it?
What is the engine's bore size?
72Sport
You may have a problem with hot air from the engine compartment going over the top of the radiator and being sucked in the front of the radiator. From your picture of the engine compartment it looks like the radiator is sitting about flush with the top of the radiator support. The top of my radiator sits 1 1/2" to 2" above the radiator support.
The hot air is drawn thru the radiator and thrown off radially off of the tips of the fan blades. The hot air then looks for a place to go. Since there is a vacuum in the front of the radiator it is sucked over the top of radiator and back through the radiator over and over again until the engine tries to overheat. Your radiator appears to sit lower than stock so it provides more space for the air to move forward. The EFI intake makes a nice air dam so the hot air cannot move toward the fire wall. When the Bronco is being driven the ambient air is forced through the radiator which makes it run cooler. The fan moves very little air toward the rear of the Bronco
Simple test is to wait until you have a good breeze and head the Bronco into wind and see what happens to the temp. Then park it so the Bronco is facing a building or? and see if it gets hot.
Look at Bronco Driver #12 pg 59, Cooler Bronco at Idle with AC. I think you can download the article for $5. Down load it. I think they limit your access time. Don't wait too long.
If it's a backwards or incorrect gasket though, couldn't it cause a heating issue without actually leaking oil into the coolant? Might have a problem then, and still pass the test I would think.
That right?
jcb9089
jcb9089
Maybe fixed!
Worked on it yesterday and might have found the issue, but not 100% sure.
The throttle body was not fully closing at idle. I moved return spring location so TB plate locks close when not pressing pedal. Ran the test twice for 40 and 30 mins at idle.
If it gets to 200 now, the pusher fans kick on and keep the temp steady. I'll do some more tests, but fingers crossed, I think it might be fixed.:eek:
Interesting. Not sure how that would effect anything, but hey, if it works, it works.
FYI though, the blade is not supposed to be completely closed. There is a specification for how much it's supposed to be open, but on many EFI engines it's a very minimal amount, just to keep the throttle blade from sticking due to high vacuum sucking it shut.
This is noticeable in cars where you have to exert more effort to get the accelerator pedal off-idle, but after that it's smooth and easy.
With some engines though, you still set the base idle speed using the screw and throttle position. So not sure how yours is set up.
jcb9089
jcb9089
Well maybe that's not it if its supposed to be that way. Then I'll have to do a few more tests before calling it good.
For some reason, last 2 tests resulted in steady temp.
