Overheat Advise
DJs74
OK, another question... is there a chance that when you switched to the EFI setup a different intake gasket was necessary? I'm not familiar with EFI setups at all. Just wondering if the EFI intake and traditional carburetor intake have the exact same port configuration or maybe the coolant flow is being blocked and not circulating properly?
DJs74
jcb9089
jcb9089
I used 302 intake gaskets. Explorer intake gaskets port too big.
I sure hope that's not the problem. Coolant is moving not blowing out cap but too hot for me to feel comfortable.
DJs74
I'm sure many others on here have gone through the same process as you've done so we'll have to rely on some experience but this in the only scenario left I can think of...
Keep us posted and good luck.
DJs74
jckkys
I've owned 3 Broncos over the last 40+ yrs. They all had 7 blade flex fans, 3 row copper radiators, fan shrouds, and stock type water pumps. These worked well for me like they did for 100s of thousands of Bronco owners. I've learned a few things about the cooling systems over time. First the highly touted after market gizmo is a waist of money. Aluminum radiators are not better, or even as good, as copper. Electric fans are no where near as good as the 7 blade OE flex fan. Retarded timing contributes to over heating. Timing should be advanced until it causes pre-ignition, to keep the engine cool. Fan clutches are just another thing that can malfunction. The OE fan never failed in over 40yrs. of use. Even with the aluminum radiator and clutch fan, the engine shouldn't over heat in Col. Sprgs. 85 degrees. I don't have a diagnosis, but replacing parts is no way to get one.
ntsqd
heratic car camper
Upper SoKA
Used to be that I thought fan clutches were a waste of time and were prone to failure. I've spent the last 100,000 miles with one on a Toyota that came to me with over 100,000 miles already on it. The miles that I've put on it haven't always been kind and some were downright abusive (chasing rolled & possibly injured desert racers, etc.). Never been a concern or even suspect.
Based on that, and previous (bad) experiences with aftermarket clutch fans I'll say if you want one to make make sure that you get an OEM one. I would go so far as to say that a used one in good condition that is original to it's donor vehicle is a better choice than a "brand name" new one.
blubuckaroo
Grease Monkey
Ridgefield WA
All good advice. ;)
We all get bombarded with convincing sales pitches about aftermarket stuff. Most of the time when you use them you end up having to modify something else to make it work. Then the problems go on and on from there.
I had been told that flex fans are junk. I tried other fans just because of that advice. None would move as much air as the factory "super cooling" fan that came on the car. In fact it's the only one that will keep the A/C head pressure down to an acceptable level at idle.
jcb9089
jcb9089
Appreciate the advice, will troubleshoot some more and let you all know how it turns out.
ransil
I'm going with check the simple free stuff first.
thermostat in backwards
vacuum leak
too much timing
72Sport
What is the fan clutch off of? Is it for a v-belt engine or serpentine. I would guess they are different inside so they must run in the direction they were designed for.
Is the water pump for a 76 or?
If this is a repeat of a previous post disregard.
If an engine is running hot it is not getting rid of the heat. Either there is a water flow issue (radiator is working fine, water coming out is cooled off) or there is a heat exchange issue with the radiator (water is coming out of the radiator still hot), that could be airflow or a heat transfer issue with the radiator itself.
blubuckaroo
Grease Monkey
Ridgefield WA
You said you've used two temperature gauges with the same results, but did you use the same sender unit on both?
Before getting too deep into this, you might want to verify that the gauge system is good. That means the sender unit and instrument voltage regulator as well.
A candy thermometer will work but at 230 degrees, you can't have the cap off. Better try an infrared thermometer.
67RT
Use ir on top of radiator and bottom. Make sure water is cooling as it passes thru and u have about 25 degree drop from upper to lower hose.
Where is your sending unit located? If in the head it will read hotter and u may be fine.
Apparently the head gasket can be installed the wrong way blocking water passages?
Also, are the lower and upper hoses on the same side of the radiator?
66broncoCT
Torrington, CT
He says one gauge is mechanical so it has to be different sending unit. To the OP about the overheating I'm no help there. My bronco overheats if I sit still for too long but with the tiny radiator I had to shoehorn in with the 300 I'm not really surprised.
blubuckaroo
Grease Monkey
Ridgefield WA
I saw that jcb9089 used some sort of mechanical thermometer, but I can't see how you could possibly check the temperature of 230+ degree coolant without it boiling out all over you. I'd like some more info on this mechanical thermometer.
jcb9089
jcb9089
update
changed out tstat to stant superstat 195 and burped out air.
Still getting hot. I watch temp get to 205 and then stat opens, temp drops to 195. But when idling, or driving the temp climbs back up to 230.
So here is what I know.
1. Coolant flowing, ( stat opens temp drops but temp does not hold)
2. Fan working (can feel fan blowing pulling air in across radiator)
3. Timing set to 10 BTDC
4. Vacuum reads 14-15 (can't find any leaks)
Getting too frustrated, not sure what to check next so going to take a step back and think about it.
bronconut73
I'm watching this thread. Getting more interesting......
Moon's74
Henderson, NV
same problems
I had the same problems with the following engine. 89 5.0, carbed, edelbrock intake, 96 explorer serpentine system with original junkyard clutch, WH triple pass radiator, Ron Davis shroud, and 195 degree stant superstat. I think that sounds like a decent cooling system. Engine would get up to 230 at idle after startup.
As stated here, cooling problems are either air flow, or coolant flow. I put on a new, OEM, fan clutch...no change other than paper sucks right up to my radiator at idle. Still got hot so I'm thinking flow issue. I was going to get a high flow water pump but was talked out of it by the vender, go figure. Don't throw money at it until you know the problem.
Anyway, I took out the stat for flow testing...temps stayed down. Must be a flow problem, right? Still, wouldn't run it that way on the highway.
Well, the "superstat" isn't as "super" as it says for flow. I got a Robert Shaw style high flow stat, 180 degree, and tested them both in a pan of water...WOW, the difference in the openings for flow are huge. Maybe some engines need the back pressure, but mine wanted the flow. I put on the high flow and have never looked back. The jury is still out on how efficient the triple pass radiator is at transferring heat, but my temps seem to be staying in check.
Runs between 190 and 210 all day long in summer heat of Southern Nevada.
Hope this will help.
jcb9089
jcb9089
Thanks! That does help a lot.
My father has been telling me to run 180 degree stat since this started but I thought I need to run 195 to keep ECM happy.
I've been hesitant to swap out but I'll give it a go.
It does prefer the higher temps for good reason. But the flow improvement of the Robertshaw was probably what put it back on track more than the lower temp.
If you can find a 195 high-flow stat then, it would probably be the best of both worlds.
First though, I would do the same test that Moon did and simply remove the thermostat to see what that does to your temps.
