Bronconut is correct jcb. While it does sound like your gauges are consistent, and most likely at least accurate to within, say 10° or so, an EFI engine does not usually act finicky (at least in the way you describe) by simply running 10-20 degrees hotter than normal. Something else is wrong.
And your oil does not get thicker when hotter. Even though at operating temperature it has protective characteristics of the higher number (what oil weight are you using?), it's still getting thinner as it gets hotter. And it's never going to heat up to a thicker enough liquid to in any way cause your motor to stiffen up and lose power under any reasonably normal conditions.
By the time your oil turns to goo, other metal parts of your engine have literally melted to slag.
In other words, not going to happen at 225.
The only thing on an EFI engine effected by heat is something electronic. Computer, ignition coil, a sensor or two, things like that. Fuel is staying cool due to the return system. Never gets hot enough to vaporize prematurely.
Assuming you're running a return system?
What type of EFI are you running? With a carburetor, that running well when cold and lousy when hot would say it's jetted way too lean, so works well with the choke partially closed. With an EFI setup, something is telling it to lean out the mixture once it warms up. Maybe an 02 sensor? Or maybe the CTS (coolant temp sensor) which is different from the ones you've been using for the gauges, is reading wonky and the computer is using the information wonky too.
Should not lean out enough to cause it to run poorly, but you never know. I've seen a ton of things go wrong because of a faulty coolant temp sensor.
Good luck. Keep checking stuff. Maybe it's simply a bad grounding scheme with the main chassis harness sending too many mixed signals and letting RFI have it's way with your electronics.
And no, I would not expect a temp reading through the rubber hoses to give you the same readings as the sensors are seeing. Any reason you did not check the IR temp on the radiator itself? Top and bottom of the aluminum would be pretty close I would think. And that's a recommendation someone else mentioned earlier too I think, so might be worth another shot. Even if it's not exactly what you're seeing at the gauge, it should still show a drop from top to bottom.
