jcb9089
- Feb 22, 2007
- 510
need some help on this one.
Converted 76 302 with explorer intake, v-belts, aftermarket stock style aluminum radiator, hayden fan and fan clutch, shroud, 195 tstat, timing set correctly, no vacuum leaks, 60 oil pressure, fires right up and sounds great.
Idles fine, no issues at all, but it gets hot. Temps keep rising if sitting idle or driving. Every time I run and test, gets to 230 before I shut it off and let cool down. Tested 2 temp gauges, with same results. Burped coolant and got all air out.
Any ideas? Replace with beefier radiator, super cool water pump?
