Squeal from hell, not PS pump
flexmerc
Good morning,
I installed the a new POwer steering pump, once complete, I had the squeal from hell! I triple check fluid in the pump, G2G.
I removed the belt for the PS pump and had the same dying whale squeal, so I know it’s not the new PS pump, what else could it be, water pump, alternator?
I removed the water pump and alternator belt, and the squeal went away.
What the hell can this squeal be?
Something changed. Did any oil/power steering fluid get on the belts or pulleys?
What type of alternator? If you upgraded and did not have the squeal before, maybe some dynamic changed after the new pump. Not sure what that would be, but it seems the alternator would be the first culprit on my list because they do it so often when upgraded.
And a real alternator belt squeal can be horrible and something to be avoided at all costs!
Jedeka
I would suspect the alternator. While ou had the belt off, did you spin the alternator and water pump pulley by hand?
flexmerc
flexmerc
Thanks Paul, FYI it is a full power steering kit from Wild Horses, primo!
So I got the alt, PS, and water pump pulleys cleaned up and un-greases (if they had any) and tighten up the belt alot more and changed the belt out (i had a spare laying around) it seemed to like the belts really tight
I put the PS pump belt on, went for a test drive, amazing drive with the new PS box and all. I’ll post on that later.
Seems to have a bit of a squeal under idle to hardish acceleration, I will retighten everything once it cools down in the engine bay
jmangi62
Good morning,
The reason I just completed the explorer serpentine conversion ahhh ,the silence is golden, till I hit the skinny pedal and wake up the beast.;)
flexmerc
flexmerc
Haha it made me think of this, I made the belt a bit tighter, and the squeal is gone.
Thanks again!
