Still can't get engine to crank over
broncoP
I posted a thread about a week ago about just getting clicking when i tried to start it.This truck ran fine before i started restoring it. I've since pulled the "Mean Green" starter out of my bronco and the Optima batteryu. I just drove it around in the snow so i know the starter and works and it's never let me down. When i swapped the starter in, in now tries to crank for a second or two, then dies, sounds like when you try and start with a weak battery. I"ve checked grounds, connections, and am stumped. The distributor hasn't been touched. The PO put in a Centech wiring harness, i've found a couple of suspect connections that i redid. Lights, heater, work fine.
Turn the headlights on, crank the engine. When it quits cranking, are the headlights still shining or are they completely dark? What happens to them when you release the key from crank?
Bronco717274
Tremont, Ms.
There's a starter for manuals & one for auto's, are you using the right one. I think the manual set's in a little farther won't work right in an auto. Or vise versa. Still sounds like a bad battery though.
broncoP
broncoP
It is the right starter, my bronco I took it from is an auto as well, and was in this truck to begin with . ,. . The Optima and starter that i have in the problem bronco, were right out of my other bronco that i drive and never has any problems starting. Just drove it today, then pulled the starter and battery out. Could the voltage regulator cause a problem? I'm just wondering if a wire came loose somewhere that i can't see.
I put the lights on, tried starting it, cranked for a second, lights were fine after. On the voltage regulator, there is a yellow wire under "A", this is supposed to be grounded isn't it to the voltage regulator? I'm going to try the battery from my Dodge Ram tomorrow just to make 100% sure it's not the battery, but pretty sure it's not. I have checked the voltage on the battery.
The only other thing i could think of is to do with the neutral safety switch. It has a B&M floor shifter on it. ONe wire got chewed up in the grinder, wasn't 100% sure where it was supposed to go. It's a 68, so it doesn't have the wiring for the neutral saftey, wires just go to the shifter. If something was wrong with the neutral saftey,or i put the wire in the wrong place, could this cause this? I had one go on my truck and had to start it in neutral till i changed.
Bukin 67
Bronco Abuser
The neutral safety switch does sound suspect. Have you tried wiggling the shifter as you start it? Otherwise sounds like maybe a bad ground, especially since the battery seems to be fine. Throw a trickle charger on it overnight and check the voltage in the morning to be sure.
Viperwolf1
electron whisperer
"A" terminal wire (yellow) of regulator goes to the battery terminal of the starter solenoid. Don't ground it anywhere. Measuring voltage on the battery doesn't tell you much unless you have a load on the battery. If you can read the voltage while cranking it'll tell you much more. NSS won't cause your problem. It only prevents the solenoid from activating (at all) when in gear. I'm thinking bad cable or connection.
bax
Old Member
Do you have the negative side of the battery grounded to the engine? and if you do, is it bolted down tight? A loose ground will act like what you are describing. So will a bad cable or positive connection.
I am not so worried about after cranking, what do they do while cranking (or trying to crank)?
Voltage regulator only matters after the engine is running. It regulates the alternator to control the recharging of the battery. I have driven days without a working charging system. Need a good battery to do it, but I have done it.
broncoP
broncoP
Thanks for all the replies. I just pulled the +cable off my running bronco and transfered it, pulled the neg off the block, added a couple lock washers and reefed on it and bang, she turns over. Now to add fluids and hopefully it will run.
Regarding your Yellow wire again, the primary one is like Viperwolf said. Always-on battery voltage.
You might be thinking of the short secondary Yellow wire though, that runs from the same point at the regulator connector, to a cpacitor/condenser/radio noise supressor that is usually held down with one of the regulator mounting bolts. Making it kind of look like it's grounded.
You're not actually grounding it though, since it goes into the cpacitor.
It's not required for the proper function of the regulator. Just for reducing radio noise. If you've got a piece of it hanging loose, tape it up or cut it off, so it doesn't ground out.
Viperwolf1
electron whisperer
Regarding your Yellow wire again, the primary one is like Viperwolf said. Always-on battery votage.
Doh! Paul's right, I forgot about that one.
