Theft Deterrent for EB's?
WARDOG
Graniteville, CA
I am finally getting back into the EB market after losing my precious '69 from a divorce 19 years ago. My, how prices have soared!
My '69 could be easily started just jumping across the solenoid. Of course I had a hidden kill switch to the electronic Fuel Pump, but given enough time that could be detected.
How have you guys modified / added theft deterrent devices to your Bronc's?
I am concerned with parking it in the city on occasion but mostly in the woods during hunting season?
I know my way around machining and welding, so if any of you want to post your homemade deterrents I could probably reproduce it.
My first post here, and I'm happy to be back in the game again.
When you park turn off your engine. Turn your tank selector to AUX. Fill your AUX tank with water. Engine will run until carb is out of gas and then stop in traffic. Thief will leave. Just remember before you start the rig you switch back to your main tank first because once you get water in the lines you will be stuck too.
Chicago71Bronco
Chicagoland
I put a kill switch hidden up under the dash that needs to be flipped in order for the ignition switch to get power. Easy, cheap, and effective for the novice car thief. If they REALLY want to steal it they will anyway. I usually leave the keys in the cup holder when I park it so it makes me feel better that even if someone decides to mess with it and try to start it they'll be out of luck.
Or you can get twin sticks and put both in neutral
TN1776
Insure it. If a thief wants it, he'll get it somehow (flatbed tow trucks, etc). I keep mine in the garage and anybody who tries to gain entry to my garage will make a lot of noise in the process. I have some very alert and aware neighbors and a dog who'd bark his fool head off.
When I go camping/wheeling, its open at night but I'm usually 20 feet away from it in my tent, armed. I've never left it outside at night when I'm not near it. Sure I take it all over town, to work, etc. Nothing is foolproof. A well-hidden kill switch will keep a motivated thief busy for a while. Popping the rotor out of your distributor also disables it from starting. I've even heard of dummy coil wires with no conductor core so nothing looks awry but it won't start.
WARDOG
WARDOG
Graniteville, CA
Rusty- I like this idea aside from the hidden switches.
Only I would probably use Naptha. The engine won't run on it, but it would evaporate away on it's own without cleaning the carb bowls or rusting the rings.
Instead of wasting valuable gas-space though, why not just turn the switch to the middle position so that it's "OFF" instead?
Same basic initial effect, but not going to stop them if they figure it out of course. In that case, your water idea is better.
Just seems a waste unless you have the larger rear tank to call on when needed.
Hate to fill the carb with water anyway.
Good idea on the naptha for that effect then WARDOG. But for starters, the OFF position might be a good way to go.
Of course, there's always the Rabid Badger that was popular a few years ago here!
Not to mention the Trunk Monkey torture device. ;D
spap
Ignition cut off, fuel selector in the middle, glock and Lo Jack
El Kabong
Driving stuff Henry built
I use the "Too Ugly To Steal" theft deterrent system.
EFI Guy
TheEFIguy@gmail
BFE
For EFI run a second tune selectable by hidden switch that either won't run at all or has the speed limiter set at 2mph.
AZ73
Lojack. Short of that, I'm installing a battery cut off, separate electric fuel pump switch, and Distributor kill. If you know how to start a model T you can emulate that on a bronco. Then of course the twin sticks in neutral and a hidden E brake switch (I'm trying to build mine into the twin sticks, one for the front, one for the back.) But in reality, a flatbed can walk off with it in about 2 min.
HB73
I was also thinking LoJack.My buddies 66 Mustang was taken by flatbed in front of his house one night. Neighbors thought it was a legit tow. No loJack but kill switch and steering lock. Never saw it again.
Friend just put Lojack in his super sweet '68.
Probably not a bad idea. We spend a lot more money on little doo-dads. Saving those doo-dads might be worth the up-front costs of a Lojack system.
taipeichris
When camping and leaving my Bronco unattended in the middle of bfnw, I always remove the coil wire and relocate it somewhere inside the truck. I use the Club on the steering wheel and usually keep windows down, doors open but bungie corded. The biggest problem camping has been bears. Last year in Mammoth a bear opened the doors and looked around for snacks. In town, the Club, alarm armed, fuel selector set to off, transfer case in neutral and i run B.C.s remote hood release. But in the city I don't mess with the coil wire.
Good luck!
:cool:
blubuckaroo
Grease Monkey
Ridgefield WA
Most auto thefts are tow-a-ways so these anti-start things won't help much. Not many people question a wrecker in a parking lot hooking up a car. I like to back in so picking up the rear is more difficult. That and a good alarm with a few of my own exciting additions to it.;)
