What have you done to your Bronco today?
65tuxedo
Bluffton
I noticed a break in one of my rear exhaust hangers recently so today was the repair. Not a bit too soon as the tailpipe had fallen down to the differential. Cleaned and rewelded hanger so it will be a while before that happens again.
JaxLax
Jacksonville, FL
Got a new job changing my commute from 7 minutes on the surface roads to 25 minutes with some highway usage; so completely replacing the power steering system (pump, box, etc etc) and a new 2-1 exhaust system is in the process of being installed before my Jan 6th start date.
BronCowie
Old Timer
Vancouver, WA
Put my new Franko Christmas card on the "job site". ;D
Thanks Franko!!! :cool:
jray
Worked on removing the spare tire carrier to install new bushings, the bottom pin is stuck!
Remos69
SW Florida
Dropped of the cover for the bronco so when the painters are done cutting and buffing tomorrow it won't be too dusty. I am out of town for the next week so the unveiling will be when I return.
Jdgephar
one step at a time right..
Yup, and how many hours available between everything else...
Plus, paint dries really slow in a lukewarm michigan garage this time of year.
No rush, can't drive it again till Spring...
Now that I finally have a place for a spare, I need to find a matching wheel. If my memory is correct, these are Mickey Thompson classic II. 15x10. Is there something close to these?
Sent from my SM-G950U using Tapatalk
half cab
Guru Bronco
Replaced my seven yr old Walmart battery that would still hold somewhat of a charge with a new Walmart battery.
syndicate1
Pro Comp 69 Series Vintage Wheel. 4Wheel Parts sells them.
Here’s a pic of the Pro Comp on my ‘74
MikeKC130J
Mocked up the timing cover and water pump, along with the serpentine conversion brackets, off of a 97 exploder 5.0
Calibronc66
Powder coated a couple parts today getting ready for new motor.
sprdv1
REBEL
Probably only plus in winter. Time for projects and hopefully in a heated space. LOL
