What have you done to your Bronco today?
JefeAZ
Tucson
Dropped it off for some minor fixes and this was at the shop
sprdv1
REBEL
Got a new battery for it today, did a fluid, bolt/nut ck and dragged it out of hibernation. Started like a champ (with the new battery, I think 9.5 years is a good run for the old one).
Considered putting on my other carb adapter and just decided to take it for a back 40 lap.
Also contemplated where to mount my new license plate...
very similar to mine other than grey hood :)
Okie69
Started a build sheet to track things I need to get... gonna be a long road!
JSmall
Looking pretty spiffy.. :)
Thank you!
I got the Winters shifter hooked up today. It was a lot of adjustment, but every gear hits the correct shift gate and detent in the trans :cool:
56f100bbw
Tucson / lakeside AZ
Air cleaner assembly
Detailing to air cleaner assembly’s need one more for my half cab
sprdv1
REBEL
Thank you!
I am just gonna have to say screw work one weekend, and tool around w/the bronco :-X:-X
jmangi62
Finally got around to using my WH bronco cover. It covers perfectly and protects my baby.;D
56f100bbw
Seat tracks and air cleaner
Took seat tracks apart sandblasted the inside put them back together sandblast another another air cleaner
Remos69
SW Florida
Installed my fabricated seatbelt shoulder Piller loop brackets
73azbronco
Finally lubed up rear axle front axle D20.
Install rollcage and top tomorrow, seats and engine run next week.
Fitz24
How did you mount the main part with the recoil at the bottom of your cage? I purchased a set of seat belts from WH but don't seem to have room to mount the main part. No room with 1/2 Cab bulkhead and cage for 1/2 cab.
Remos69
SW Florida
Fabricated a mount. They are humvee seat belts. Lat me known if you need a pic. Bronco currently at mechanic awaiting replacement crate motor so it will be a day or so..
No Hay
Washed it this morning. I have an appt with an appraiser tomorrow that JefeAZ happens to know here. I've never seen an appraisal in action or the results of one. I'm curious if I'm over insured, under insured, or if I need to be prepared if the new '21 Bronco is better than I expect and need to help my checkbook ;D
