Thought about setting it on FIRE!!!
Let's see....
Went to the junkyard to pull a fan clutch from a 97 Explorer V8 to replace my faulty one. Turns out the crappy Chinese fan wrenches I rented from Advance Auto were a bit larger than advertised. It's supposed to be 36mm. After I rounded off the nut on the fan and ruined it, I came home and my caliper measured the wrench at 39mm!!! WTF??? Guess you get what you pay for. That was the ONLY V8 explorer on the lot and a new clutch is $100!!! Not sure what route I'm gonna take on this one.
After that, I went to have a PS pressure line made for my 4x4x2 box I am attempting to install in place of my scout box. They RAPED me for $90.00. Turns out I could have purchased the same line for $24.99 from BCs!!!
Came home to install the 4x4x2 using the adapter plate from West Coast. I found out, after the fact, this plate is part of a batch of bad plates that has alignment issues. Had to ream out the frame a bit to bolt it on. Went to bolt the 4x4x2 to the adapter plate only to find that it too is out of alignment and will require I ream the box holes about 1/4". Even if I do get the box bolted to the plate, it places the box very low on the frame and will prevent me from installing my pressure line since I am using an adapter at the port and then a 90 degree fitting so it extend out a tad more than a stoke line. So there is no way I can use my expensive adapter plate with the PS line I want to run.
Anyway, I bolted the 4x4x2 to the front hole, drilled the lower rear hole and have stopped there for the day because, quite frankly, I do not have the balls to drill the upper rear hole at the angle required to keep it out of the cross member. Maybe tomorrow. Otherwise, I am gonna set it on fire.
FML
Thanks for letting me vent.
BTW- I know this stuff is all my fault and not the bronco's but someone has to be my scapegoat.
