I'll pm you my addy.
I am using my adapter and it works great. Shortest and now that I've figured out flexplates it's an easy, inexpensive and dependable install.
10deg spout. I will have to look on the tunerlogWhat was ignition timing? A lot of the OE timing I’ve watched on an OBD-II port scanners were showing very advanced timing at idle.
Timing that’s too retarded could also explain hot exhaust temperatures I would think.
I was gonna ask before but got busy, but wondering how much the rebuild kit runs if you got a price breakdown. Seems like kind of a pain but regular shocks need to be replaced so maybe it comes up even anyway.Had Jensen Bros Racing rebuild my ORI struts. I learned they typically last 5 yrs or so before a rebuild is due. I had 7 yrs and when the seals leak they usually hydro-lock.I didn't want this to happen on a trip so they were due. I was going to do this but shaft polishing was necessary.
Thanks Brian…I had found them on JBR. About 130$ for the kit so I suppose like replacing a high dollar shock. Seems a lot for mostly small seals and parts but its quite a number of them. And no spring fatigue do deal with. Maybe could polish if needed with a drill turning it and a handheld belt grinder with the correct fine grit belt. Similar to finishing a crank On a smaller scale.Been out of cell service for a week.
Can't remember the price for the total of parts.
Try Jenson Bros Racing in SLC on line. They have all the parts and are very supportive answering questions, etc.
https://jensenbrosoffroad.com/
Mine were old "relatively" and needed several updates. I haven't been able to accelerate or corner really since I have 20 miles on it and STILL waiting for a new tune but they feel better for cornering than before. Different weight oil, new seals can't hurt performance of them.
Mountains are for snow skiing…flatlands are for water skiing (WARM)I was water-skiing in the mtns of Idaho last week.![]()
Yeah, but it's so freakin' beautiful.Mountains are for snow skiing…flatlands are for water skiing (WARM)
PS: Some relatives have a cabin on the lake around McCall and the cousin in West Richland liked to go to Priest Lake
Hey. cool….the Hobie in the middle with 2 blue stripes is a twin to mine. The multicolor further out behind it was called a
Naw, a little time spent tacking into the wind and you get it. A cat doesn’t pivot as well as a single hull, just takes a bit to get the feel for it. There would be places (ex. Docking in a cove) that need more experience, but getting around the lake can be taught in a short time. You’re still required to carry a paddle just like a powerboat as well.Always wanted a Hobie.... we have lots of wind around here in the early summer so I'm sure you could clock 20mph on one!!! I would need to have another truck waiting on the other side of the reservoir!!![]()
