Bump steer and wandering
Jonathan_Cole
I have a 1966 bronco that I recently put a TBP 2.5 inch lift on. I have replaced springs front and rear, shocks front and rear, 14pc bushings with 7* bushings. An adjustable track bar and drag link were added with a stock pitman arm.
The bronco only has 39k miles on it and has always had a wandering issue. Of course, this got worse after adding the lift, wheels and tires.
I thought I had it figured out. The stock manual box was sloppy so I replaced it with an aftermarket new box and cut the steering shaft to add a collapsible shaft.
Other than some minor wandering, all was good. Until last weekend. I drove it to the grocery store and back which is about 4 miles round trip. A few times during the trip the bronco would veer to the left.
I got home and noted that the sloppy feeling in the steering was mostly to the left.
I don't see anything that has obviously changed.
I know this has been covered here several times. I've read tons of threads but I can't find a straight answer. I've seen drop pitman and no drop pitman. Track bar drops and risers, as well as tro/tru.
Which direction do I need to be looking here?
Sent from my Pixel 3 XL using Tapatalk
doran4x
Let’s see some pictures of the front end. When you turn the steering wheel back and forth does the front end move?
Timmy390
Conway, AR
Sounds like something might have let loose as in broke or cracked. I would get under the rig and have someone turn the steering wheel and watch for movement. Frame crack or T-bar mount crack, bad tie rod end......Check everything. Tire pressure too. Maybe you have a low tire?
As for what combo works? It's different for each rig. I run drop T-bar bracket, drop pitman arm, adjustable T-bar, adjustable drag link and 7 degree bushings. My rig drives nice at any speed (faster than I'll admit to going, honestly I was just flowing with traffic officer) On some crap back roads it's all over the place but it's clearly a road issue not a rig issue. I was going to sell my rig if I couldn't get it driving right so I thought everything at it.
Tim
J
Jonathan_Cole
Here's some pics
J
Jonathan_Cole
I guess I should also add, I haven't had an alignment yet. I've lowered the air pressure all around to 27. I just pushed up and down on the front bumper as hard as I can I don't see any movement on the steering wheel. I've manually pulled on each tre, drag link and track bar and nothing appears loose or moves. The only thing I'm down to is the steering box which is new. I get about an 1/8 of a turn on the wheel before anything moves. The box had a centered mark on the output shaft and body that the company said to make sure was aligned for install. It is. When the lines are aligned and wheels straight, the pitman arm is pointing slightly right looking from the front. I guess I could remove it and tighten up the drag link to see if anything improves.
B RON CO
Statesville, NC
Hi, I would drive it with the steering stabilizer removed. Then I would put the front axle up on jack stands and go over the whole front end. I'm wondering if you need a trac bar drop bracket. You can learn how to set the toe on a level pad. Good luck
m_m70
Prescott AZ
I'm running all this as well with my 2.5" lift and drives great!
Re-torque U-bolts on rear springs.
Definitely!! I had to do this right after I installed the lift. Very squirrelly. Once re-torqued the rear, things have been great. Shoot, thinking about it it's been over 23 years now!!
Then that's where you need to look.
First the lift will do it, but more on that later. The tires and wheels, what size did you switch from, to? And what size wheels with what offset?
Probably needed it, but there are many things on a Bronco that can cause or make wandering worse.
Not only is that not good, it's dangerous! Figure that out before you start driving it again.
What exactly did it do, and when? And how severe was the veering?
Define sloppy and under what circumstances? All of this talk about how to get rid of wandering may have nothing to do with another underlying problem with a component that you need to correct.
That's because you were not looking for a straight answer. Like many of us, you were probably looking for a single one-size-fits-all definitive answer to your problem. But without knowing what your problem is, that answer does not exist. So you won't find it here.
Otherwise, the answers really are out there.
That's because history dictates that earlier Early Bronco owners as a general group were cheap. And the vendors just followed suit for the last 50 years or so.
Back in the day, nobody wanted to hear that their lift was going to cost another $75 bucks for a dropped pitman arm and trackbar bracket, so they didn't listen and didn't buy them. And to most, it was perfectly fine with their modest lift. Heck, in the beginning there weren't even any dropped pitman arms unless you found one off of another vehicle that fit the bill. And adding just a trackbar drop without a pitman arm just made things worse.
In fact, we still see to this day (right here on this forum a few weeks ago I think?) Broncos with 3.5" of lift without the drops.
Despite the fact that you "only" lifted yours 2.5" you still radically changed the angle of the steering and suspension linkage outside of their stock settings. This might be acceptable to some, but not if you're trying to keep it (and you) happy on the street.
Most say you don't need them for 2" or less. Well, you don't have less, you have more! I know it's only a 1/2" more, but it's still more. And frankly, even 2" is borderline and while we might have accepted it back in the day, most of us would find it completely unacceptable today.
So you are probably going to have to get a dropped pitman arm and trackbar bracket because that's what's needed at a minimum to bring the angles of the draglink and trackbar back down to near-stock.
I know that's primarily stated to be for reducing bumpsteer, but wandering can be related to bumpsteer and those same components get rid of some of the newly installed vagueness of steering feel that you get after a lift. Lowering the angles back down should impart a more direct feel to your steering. Which in itself helps with wander.
You can play with toe-in without even measuring, but it's best to do it right and measure consistently.
However, a full alignment readout is helpful and getting them to set your toe-in to a known value is a great starting point for all the fiddling you're going to do in the driveway.
Again, what size tires? Someone just posted up an alignment sheet showing toe-in measured in inches, but most racks these days use degrees as their reference, which does not give an accurate real world measurement if you have changed your tire size.
But it's still a great starting point, and you can convert it with math, or one of the charts that does it for you.
Keep playing with pressure. Depending on the tires and wheels, you might be able to go even lower and still drive at high speed safely.
And like so many settings, you can easily go back up if needed.
Good to know, but not a definitive test.
Can't do it that way. Period...
You will never see the fine movements in a loose component that can cause minor wandering by hand. You need to do the test that Timmy described above.
For this test you need the full weight of the truck on the ground, and a helper up at the steering wheel turning it back and forth while you watch for movement. Literally watching everything and everywhere. Even in the back!
The helper does not have to turn the wheel lock to lock either. Can be done with just a quarter to half turn in each direction, but they need to do it continuously while you're under there looking at trackbar bushings AND brackets AND bolts, steering box mounting to the frame, rod ends, wheels and knuckles (king-pin bearings) and all that.
With manual steering you rarely see a cracked frame. But it's not impossible, so it's a good thing to watch the box and how it flexes on the frame.
Pretty normal and probably good. Not great, but not out of line for an old component. You might be able to tighten it up some, but I would not touch the preload adjuster until there is nothing else left.
That's good, because that's more important than most realize.
Is it the original pitman arm? The '66 through about '74 arms did point one spline (10 degrees) to the driver's side. So that sounds normal.
After that the arms were oriented straight back. The offset never seemed to cause any trouble in itself, but either way is fine as AS LONG AS THE BOX REMAINS CENTERED.
Not sure what you mean by "tighten up the draglink" but removing the arm sounds unnecessary at this point.
But do the test outlined above and see if anything is truly loose.
It's on the list to do.
Hopefully on the short list.
Or just do it yourself in the driveway/garage. You only need to set toe-in for the moment, but an alignment on a rack by a professional is always a good thing so that you can at least get a printout of what all your settings are and you can move on from there. Maybe it's perfect, maybe not.
Probably not...
Speaking of lists, here's a short list of things that can cause wandering in a short wheelbase vehicle like ours.
1. Tires:
Tire age (not wear, but age), tire pressure, tire wear, tire tread pattern, tire width.
2. Wheels:
Wheel width, wheel offset.
Trackbar:
Bushings, bolts, brackets, and bolts. The lower one can break it's weld underneath and get slightly loose. Just enough to cause minor wandering.
3. Wheel bearings improperly adjusted or worn out.
4. King-pin bearings improperly set or worn out.
5. Taller lifts leading to improper steering linkage angles.
6. Loose steering box or cracked frame.
7. Other "stuff"
8. ALL OF THE ABOVE ADDED TOGETHER!
Sounds like you have many of the parts replaced or dialed in, but as you can see by this discussion (that someone in the future will read and think there was no straight answer either!) there are still plenty of areas to check.
Lucky you...
good luck.
J
Jonathan_Cole
I was definitely not looking for a one size fits all answer. I've read posts from over 10 years old to a few months old. I think the consensus is, every bronco is different.
Tires, not sure of the build date. They're bfg takeoffs from a Rubicon 255/75/17. The wheels are 17x8 . The prior wheels were aftermarket 15x6-7 not sure which. 215/75/15.
The veer is not severe but enough to get your attention.
What I meant by tighten up the drag link was move the pitman arm closer inline parallel to the frame and adjust the drag link accordingly.
The pitman arm is not original as the drag link wouldn't fit the original. This was one of many parts that I wish I had been told during the original order so all parts could've been ordered at once.
The alignment is definitely on the short list of to do. It's just getting a day when I can get it to the shop and home the same day.
I checked, repacked and torqued wheel bearings when I had everything apart a few months ago.
This is not something that gets driven often, or far, so it probably doesn't have 50 miles on it since the lift has been done.
WILDHORSES
USA
I know it's only 2.5 lift but when they act this way I like to go drop track bar bracket and drop pitman. In that order if you want to check out how it changes the ride it in stages. Also in agreement with losing the stabilizer until it tracks correctly.
Jim
J
Jonathan_Cole
Improvements have been made. I torqued the lug nuts, they were a little loose. U bolts, I don't know what I torqued them initially but it took a few turns to get to 150. I removed the stabilizer and it has a much better and natural feel. I still need an alignment.
brewchief
I don't believe it was just bronco owners being cheap, I think back then people just accepted that a vehicle wasn't going to drive well once lifted, we have different expectations now.
I also think that many times it really wasn't necessary, about 10 years ago I swapped out an old set of superlift coils for a new set of deavers, both 3.5", my bronco before the swap drove fine with a trac bar drop but no pitman arm, after it bump steered very noticeably, the old springs were simply so stiff that there was minimal movement to cause bumpsteer.
Sent from my SM-T510 using Tapatalk
All going good so far.
Typical of having been driven a bit. It's always part of the procedure to re-torque u-bolts after a few miles.
Used to be recommended at 500 miles when trucks and Broncos were our daily drivers, but when only driven occasionally you might as well do it after a month or so just so it's not forgotten while living life!
But at 150lbs, I'm guessing you have the upgraded 5/8" u-bolts along with one of the super thick top plates?
If not, that's a ton of torque for smaller u-bolts. And would certainly bend the corners over on a stock stamped top plate.
You'd have seen that happening though, so presumably it's not basic stuff back there anymore.
That's good too. Glad that was recommended previously. Many of us have run without them for decades, but when they're in good condition and everything is working properly too, they don't seem to cause much trouble just by being installed.
Wonder if yours is binding up?
Can't wait to hear results from an alignment check, or from you playing with toe-in settings.
