charlien
I've been reading literally hundred of posts in forums and there seems to be (or I seem to be) confusion about using the stock explorer sensors when doing a swap.
I'll be swapping a 98 explorer 5.0 engine and want to use as many of the sensors as I can. I'll be using a A9* computer. Here's where I'm confused.
1. Some say the explorer TPS is different from the mustang and it has to be swapped.........some have used the explorer TPS though. Are they using the mustang TPS just because of the plug, or does it really send a different signal?
2. I'll be using the explorer TB, fuel rail, and injectors; I've read that I need to use the 94-95 mustang 70mm MAF. Will this work with my A9* computer, since it's from and earlier mustang?
Here are some other things I've found, most seem to agree, please let me know if any of it is wrong: I'll be using the RJM harness
-ECT sensor: move from the side of the coolant tube to the top.
-ACT sensor: tap the manifold; or place it between the MAF and TB (can also use the stock explorer tube. Explorer and mustang ACT sensors are the same, with the exception of the plug
- use monster mounts to retain the explorer oil filter cooler assembly.
- BC has headers for the "p" heads and also cables for the TB and cable for the AOD trans
Any other solutions to problems that you have seen or heard of would be appreciated. I just want to get well prepared to avoid any waste of time and most of all MONEY.
