migs Bronco Barn - a chronicle of what's happening at the new place
migs
migs
Thanks all!
So we went to the East Coast Bronco Roundup, Lots of pictures of that in this post, now back and started cleaning up the big mess I had created from all the last minute prepping for the trip. Need some clean space to get back to work on things...
Things like Tasker's tub that had been put on the back burner for a short spell.
migs
migs
So I moved tasker's chassis over into a better position to get that exhaust system fixed up and back together. Was starting with a multi piece Y pipe that needed a little tweaking and would be better off welded into one piece instead of clamps holding it together. So that's what I did.
migs
migs
With that done and cleaned up a bit I worked on fitting up the rest of the exhaust system. Tasker wanted to swap out out the old flowmaster muffler for a new Magnaflow, so on that went and the exhaust is now complete.
IMG_0063.jpg IMG_0064.jpg IMG_0065.jpg IMG_0066.jpg IMG_0067.jpg IMG_0068.jpg IMG_0069.jpg IMG_0070.jpg IMG_0071.jpg
migs
migs
Now that the chassis is pretty much buttoned up I suppose I should roll it on back and get to the part that everybody is waiting for, especially tasker...fitting the body! 😁 So here it goes, let's get started mocking it up.
migs
migs
First step is getting it close so I can see what hits or might be close to hitting, and to get an idea of spacing on the body mounts along with figuring out what I'll need to fabricate to make it all work. So far it's actually fitting better than I was expecting, there's a few issues to deal with but overall not too bad.
IMG_0081.jpg IMG_0082.jpg IMG_0083.jpg IMG_0084.jpg IMG_0085.jpg IMG_0086.jpg IMG_0087.jpg IMG_0088.jpg IMG_0089.jpg
migs
migs
And to close the night out... a quick little mock up with some fenders and a grill for looks and perspective. surprised I actually had a spare grill that matches the green😄
tasker
all knowing of nothing
NH
Wild horses integrated 1" body mount kit might be the answer?
migs
migs
Might be a good place to start, if you're ok with the additional height. Will need to go up a little anyway compared to what it is now in those pictures.
fatboy
Glad to be here.
New Hampshire
I was thinking you are going to need something with some of the space you can see between the Mount and the tub while it’s resting on the frame.
migs
migs
Yeah, the body mount positions are at completely different heights as compared to a steel tub or even a newer glass tub. The four rear most mounts will need spacers to make up the difference, right now the plan is hopefully to build a couple of cross members to do so and possibly also provide points to tie into the roll bar.
fatboy
Glad to be here.
New Hampshire
That should add some overall rigidity to the glass tub too. I would love to see a functional tailgate in there, but I understand that tub is probably not up to the challenge.
bigmuddy
Marthasville Missouri
I have a local friend that does that on all his builds when adding a body lift. Great idea.
migs
migs
Also did a little more workshop cleaning in the ongoing effort to unbury Lil' Rusty(the blue one) so I can get back to work on that as well.
Getting new ideas in my head....
NGABronco
N. GA now South Carolina
