pa69broncoguy
- Sep 6, 2011
- 566
the outside is exactly the same as the 351 distributor. Inside is the same as the 3.8 block hole and is spaced up 3/4" I would take the cam sensor you will be using and your distributor from your 351 and make sure the person doing your machining knows what you are trying to do.
