My 351w Explorer EFI conversion thread
chuzie
The collar for the cam sensor was so expensive. Is there another solution? I wonder if a 3D printer would be a good candidate for this item.
mjramacher
I had collar made up for me it was 110.00$ I didn't want to pay that much but didn't have much choice,the guy at the machine shop said if I wanted 10 made he would do them for 70.00$ a piece.
pa69broncoguy
pa69broncoguy
It does seem a little pricey but when you concider the price of a decent distributor/coil it doesnt seem too bad. I think 3d printers only do plastic dont they??
pa69broncoguy
pa69broncoguy
It would be a little rough to dish out $700 for 10 adapters. Till you shiped them and accounted for your time/inconvenience it would turn into a charity act in no time. I wish there was a better way but I dont know of it yet.
pa69broncoguy
pa69broncoguy
I pulled a bonehead move the other night, i put my heads back on and bolted up my headers. The next day a friend asked if i got the heads put back on and asked if i put the o2 bungs in wile i had the headers unbolted. It was an instant dooooh!!! moment. I pulled the pass side off and got the sensor bung welded in tonight. I cleaned up and reused the explorer bungs. I also painted up my new autozone oil pan tonight too. The paint turned out good i couldnt belive it went so well. The pan and paint were both warm but i took it outside to paint 19* F outside but it sprayed great. It should be dry enough to put on tomorrow.Here are a couple pics.
pa69broncoguy
pa69broncoguy
Today i bolted on my new oil pickup, installed my intake manifold and fuel rails. I also hooked up my rear rubber fuel lines that connect the fuel rails and made a hold down for my distributor.
The drivers side fuel rail needed to be modified to clear the firewall and wiring harness. I heated up the fuel rail with a propane torch and the rail bent very easily.
The rubber fuel lines I used are specificly for efi and I used efi clamps. The lines were very snug going on so hopefully they will be good.
I made up the distributor hold down from 2 original hold down brackets then wrapped it in some thick steel and welded it together. It smoked a lot when welded and welded a little weird so im thinking it was cast iron or pressesd metal. I laid the heat to it and threw it in a bucket of ashes when i was done so it would cool slowly. Im thinking it should work out ok since it isnt a high stress area anyway.
pa69broncoguy
pa69broncoguy
slowly progressing
The other nignt I put on the explorer timing cover,rebalanced dampner and water pump.
Tonight I started to look at my acessories, I bolted on the alternator/idler/tensioner. I started to look at my ford truck power steering pump mount that I had previously modified to accept the saginaw pump. It looks like i might be able to cut off 2" from the back and it should be lined up just right.
I see that most of the setups have a idler pulley on the top between the ps pump ans the alt. Is this really needed, it looks like it could be done away with on my setup. Any input? Here are a couple pics.
pa69broncoguy
pa69broncoguy
The other night i got my drivers side header pulled and welded in the 02 sensor threaded insert. I wrapped the collector because it is close to my clutch line. I got it all bolted up, hopefully for the last time;D here are a couple pics.
mjramacher
its looking good I am getting my motor back today I will start putting some paint on this weekend I glad somebody else was doing this same swap at the right time I hope it all went well for ya so far I do have one question did your cam sync collar require a o-ring and if so where did you get it.:)
pa69broncoguy
pa69broncoguy
mjramacher, there will be an o-ring. Im planning on just re-using the o-ring off my distributor ,it should be fine because the specs are the same as the outside of the distributor.
tasker
all knowing of nothing
NH
keep going! my build is stagnant and this keeps reviving me! MEB Round Up with it this year?
mjramacher
thanks that's what I thought but was not sure keep up the good work I will be starting mine tomorrow I am excited been waiting almost two months for this.
pa69broncoguy
pa69broncoguy
I drove it to the roundup in gore last year with the carb. This year I plan to drive it to the roundup too ,hopefully with the efi done:) It looks like it should be about the same distance for me to both places about 4 hours.
tasker
NH
hopefully i can check it out....gotta get moving. Would love to have mine there this year as well
pa69broncoguy
pa69broncoguy
Glad your enjoying the thread, Its always exciting to start a new project. It always motivates me when I see what everyone else is doing. It seems like such a huge project but if you break it down and concentrate on one thing at a time its not really as large as it seems. Im getting anxious to see how it works, hopefully we will find out fairly soon, just a couple things left to take care of.
tasker
NH
bocci, i hope. My good buddy Steve is coming by tomorrow to give me a boot in the ass....
pa69broncoguy
pa69broncoguy
I picked up a 02 windstar computer mount the other day, I think it will work much better than the explorer one. It looks like it will push it out about 2" from the firewall. It took quite a bit more to get it out than i thought it would but they only charged me $1 for it. What a score. Here are some pics.
