GRN_MEANIE
- Joined
- Aug 2, 2005
- Messages
- 553
Mine is 82" with 37 Krawlers
Well the last couple of days has had some ups and downs... Biggest issue being the tear down of my 20 year crawler project... Sad Day- Click Here. It was like a family member...
Anyway, I will be recovering some money for the Bronco Crawler.
I also got the grille narrowed 14"... I am a little concerned how far the 44s on 10" wide beadlocks with 3" back spacing will stick out...
Looks good with the 14" out. Is that pic close to ride height?
Floor to frame no- it will be about 5" taller with the 44s on it.
Axle to frame- this is where I am planning on ride height, but that may continue to change as I work on it.
I am trying to keep it the same height as my '75 with 37" tires and 7" lift. Top of the cage on the '75 is about 82" and just squeezes into my garage- which is where they both will reside.
sounds about right, how much up travel will that give you?
I'm sitting at 6.5" of up travel on 42's with an overall height of 80"
im dropping to 40' maxxis creepys and 5'' of up travel so i should sit at 77''
I've got air bumps so ill be ok in the whoops ay moderate speeds.
its cool to see how you cut your grill, i pulled out 13.5'' and merged the "f" and the "d" together. you went with a cleaner look. more work but clean![]()
It will be 6" up travel, 10" down on 16" COs. if I am within an inch or so of the garage door, I will drop air pressure to get in.
I will do air bumps later in the build... Want to get the links and COs in first.
I actually think this way is cleaner... No FD slammed together. It required more cuts and lining it back up was a bitch... But there are no letters- all smooth.
Yep its certainly cleaner, my decision was made for me. The last guy to cut & splice the grill together was jesse james so it only made sense to do it exactly the same. The grill was the only piece I wish I hadn't effed up in the roll overI was thinking of having a piece cut that could go over the "fd" like a new ford logo or something cool
MR really---just looked at taskers build thread, that's one hell of a nice looking truck---you guys must be buddys---no offense tasker, i meen the green machine.
And that green machine does go like a raped ape, or in this case a sasquatch...;D
beauty....what's it like to own 2 badass rigs?
Popped a valve cover off the 351 and it wasn't great. Engine was running, but full of sludge and some broken spring parts.
Picked up a complete running '94 351w with 80k miles. Good foundation for the aluminum heads and roller rockers I got with the Bronco!
Is the E4OD flex plate the same as the C6??
