What have you done to your Bronco today?
JeepGuy
Looks great!
How are your knees holding up?;)
It was a pretty intense leg work out. 😁 Luckily I have the perfect height step stool to walk up in to the bronco suit was like being on the stair master all weekend.
Howard2x4x4
I've been working on installing an F150 tilt steering column and soon realized that I would not be utilizing the ignition key or the gear shift lever, both of which are on the column. I decided to utilize both openings for other accessories to be added later.
gnsteam
Lincoln NE
Nice job. I have the same roll cage bundled up in the shop waiting assembly. Always great to see pictures and get pointers from others who have experienced the install. Thanks for pictures JeepGuy, I will be following.
JeepGuy
Will do. It's my first time trying to weld a cage together. I plan on picking up extra tube and scraps and really working out the techniques. Once you understand the angles on the cage and where to grind it's just a matter of not taking too much material off at once, and taking it off evenly from both sides of pre-bent tubes. The more hands the better to get it started.
Side note, I'm not kidding when I said it kicked my ass for a couple days of actual work.
One thing that definitely helped with squaring it all up was using the inner bars to help align everything. You could do the same with anything really. I believe the measurement by TBP was 27 1/2" over all width between front and rear hoop but that will obviously vary depending on how much material you remove.
What worked for me was finding center on the front and rear bars, measuring equal distance out each side ( I think I did 8 inches each direction, so 16" spread between the bars, then securing the inner bars in place in place with straps. Those little magnet semi-triangle thingy's come in handy here. Then all you need to do is try and square the legs up on the bronco floor. This helped keep everything up in the air to while I didn't have anybody else around to help hold things in place. I squared the legs by measuing back of the fender well, and away from the rear side panel.
Below is a shot of that set up. Nothing there is welded in. I was still trying to get the right distance, but you can see the process.
gnsteam
Lincoln NE
Great info, Thanks Jeepguy.
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
Well after getting the rear axle 3rd member in a while back and starting to fill it back up, I promptly ran out of fluid. So today I got more fluid and got it topped off and closed up. Insp the rear d/s and u joint and then got them lubed and reinstalled.
Got the front d/s back in, and then finished the JB Custom Fab (via Toms Off Road) twin sticks installed. I had to remove the PO cobbled up and modded stuff 1st. And then the real fun began, it was not a simple bolt on process of the new stuff.
The previous twin sticks had a large alum spacer block attached to the side dvr of the mount (you can see it in the pic) and lucky for me it was there, because I needed to reuse it. Even though the directions did not say anything about needing it. But the new twin sticks would NOT mount up without it. So after some hole redrilling and more/better cutting of the 2 shift rod tabs, and then bending the twin stick lower arm brackets a bit, it is in.
Putting the rear tires on tomorrow and then its coming out the garage.
sprdv1
REBEL
Glad you're making progress brother....
sprdv1
REBEL
Finally got back onto this. Not gonna lie, this cage has kicked my ass over the last few days between bars falling on my head... lol... and just learning how to cut round tube properly for the install. I don't have a metal chop saw, so everything was done with hand grinders. The product itself is great and I can definitely see why TBP leaves the tubes long. I had to reposition the front cross bar at the higher point to keep the angle on the front the same as the rear part of the cage, otherwise it would have angled down. This way it all came out level. I think I've crawled in and out the Bronco about a thousand times this last weekend trying to get it all fit. View attachment 879298 View attachment 879299 View attachment 879300
The plan now is to practice practice practice welding round tube to plate steel or other tube before I do the cage. It's been awhile since I've put any real time into welding and I figure if I just jump in, the first welds will look like crap, and the end welds will start to set in like they should... trying to avoid the crap welds... lol.
Once the main joints are all welded up inside the Bronco i'll pull it out and handle any of the hard to get corners or bottom side. Then I have the grab bars, seat belt attachments, etc... Not sure if I'm going to powder coat it, or just about a couple cases of SteelIt and spray it myself.
that hard work will pay off for sure :)
sprdv1
REBEL
Another horrible day🤣
Explored back country in Arches NP today. Got to see what less than 1% of the visitors get to see only saw 4 other vehicles on the 40 miles of dirt we covered today.
you brag too much, but glad to see someone has a life :)
Gupster88
Guppy
Tillamook OR
Got the front quarters , hood and grill bolted on today. Hood gave us fits. Little shimming on that drivers side…. Yeh , I forgot to get the other headlight bezel on….
rcmbronc
Tomah WI
Got my new front housing from Currie today. Very nice piece.
