What have you done to your Bronco today?
399strokerEB
Wasilla, AK
Rebuilt the steering column in my 74 today.
Nice. Did you run afoul of any of the typical “73-74-75” parts change/transition crap that many ‘74 owners have to deal with?
399strokerEB
Wasilla, AK
Only issue I had was I had a 73 style indicator, and the body harness doesn't have the factory connector that I still need to find.
Gupster88
Guppy
Tillamook OR
Got the seats, rubber mat and floor covering stripped out of new bronco. More and more pleased with what I am finding on this one. Very solid. Only real rust is drivers side floor board. Rest is as good as it gets..
Ether
Tulsa
Got my Xterra box mocked up on the frame, still needs some adjustment with washers/bolts.
Used the stock Xterra lower steering shaft to mate with a 3/4 D x splined joint and cut the OEM EB shaft to a "D", will probably still weld the "D" side. Excited about the 3.75-4 turn box and 3/4 ton Steering!
Got my Xterra
Gupster88
Guppy
Tillamook OR
What kind of dolly’s are those and do they move ur bronco fairly easy?
They are cheapies I got from Northern tool. They roll really nice. Once you get wheels spun around to direction you are going they roll easy. I am happy with them for the price. Only draw back is having to jack up rig to get it on them. They more expensive self jacking ones would be nice. But these are pretty bulletproof.
hsach
Members Only
I bought the same one from summit years ago, very happy with them. Summit Link
I almost forgot to congratulate Gupster88 on the incredible bronco score. Well Done!
Hallboss
PNW
Rear axle seal/bearing replacements on the 9", third member reseal, and fixed the mismatched rear brake drum parts from PO. Installed parking brake arm/springs and now working on Estopp electronic parking brake assembly. Will be good to have a parking/emergency brake finally!
Ol'Blue
Made 1” spacers for the bump stops to protect the shocks from bottoming in the rear. Next will be the fronts 1.5”.
stupidboy
My wifes porn star.
Morrisdale Pa.
I fabricated these 2 units to use with the sway bar I’m going to install on mine.
I have dual shocks and my forward shock is in the way of me doing tro, so this is my fix.
BroncoJimbo
Long-term owner
North GA
Replaced the battery. I could have sworn I had just bought the Bronco a battery but alas, the journal does not lie. This was a Diehard that almost made it three years. Almost.
It turns over with alacrity again.
