Well, the new Summit adj from 4.120-4.220" dia ring compressor worked well. Never used one of the "adjustable" ones but they didn't have any the correct size for my new pistons. Took a bit of adjusting for the correct diameter but then it worked well.
Pistons are in, thrust #'s are double checked, but my old torque wrench died. I pulled it out of my box and it didn't click when rotating the grip which changes the torque setting. I've had people using my tool box the last month so I'll have to ask. ODD that when I pick it up the handle won't rotate and it wouldn't hold a setting. Seems odd it would die w/o being used but ?? Good luck strikes again right? They usually don't die sitting in the Snap On box...
New one is already on it's way as the 2 torque settings I need won't be accurate enough on my small torque wrench or my big one... of course! Will borrow my buddies tomorrow am.
