Dan Wheeler's Remote Mount TFI Thread
DanWheeler
DanWheeler
Kirkland, WA
Thanks, VW! I must have looked right at it! I definitely found that page when I was looking. Makes perfect sense, my 3rd from the left 15a fuse was blowing and thats what powers the TFI.
I checked out the TFI module as per this article:
http://351winsor.com/joel/Ignition_Systems/tfi2.html
and everything looked OK on all 3 of my TFI modules. One of them blows that 15a fuse every time and at least one of them works intermittently.
I had a no-start condition with my newest TFI module, swapped it out for a junkyard spare, engine started right away. Thought I had it nailed to a TFI issue. I had to wait a few days before I could get back to it and when I put the newest TFI module back in to confirm a no-start again, it started up right away! I hate intermittent problems.
DanWheeler
DanWheeler
Kirkland, WA
Went to the electronics store and picked up a heat sink and some shielded 18/3 cable:
Viperwolf1
electron whisperer
Might take a good look at the connector and wires.
garberz
Bronco Influencer
Conejo Valley, Ca.
X2, I just experienced this same symptom with another Bronco. Ron Francis EFI harness. Turned out to be that both the TFI and MAF female terminals in the connectors were loose, as in, needing to be crimped more, to make a good connection. The tech guy from Ron Francis said that has been an ongoing issue with their harness. The TFI and MAF, use the same female terminal.
Mark
toddz69
on a related note - just for fun I popped open a junkyard TFI I had laying around that was blowing one of the RJM fuses every time I turned on the ignition. It's not what I expected. There's a 1/4" thick layer of clear goo covering a bunch of electronics inside there:
Dan
Looks like a nice thick coating of conformal coating.
Todd Z.
Bronco_69
Monette Ar
that sounds like the sensor inside the distributor. I have seen it three times in the last few months on different 5.0's.
start reading around post 489
http://classicbroncos.com/forums/showthread.php?t=216576&page=33
pcf_mark
Nice work! Just wondering - if you could put it anywhere why not put it inside the cab? Plenty cool, sorta dry.
DanWheeler
DanWheeler
Kirkland, WA
thanks, I looked and looked and looked for ways to get it into the cab but I couldn't find a good place for it that would be easy to access and didn't require me to extend the RJM harness. I think this will be a temporary location and I will move it into the cab when I re-do my dash.
Its not a very good location given the big tires and the lack of fenders but I'm going to build a little shield to protect it from slinging mud. It stays surprisingly clean and dry in there for not having fenders. I think all that clear goo inside the TFI should protect the important parts from water anyway.
DanWheeler
DanWheeler
Kirkland, WA
also, I think I'm going to need a remote mount TFI distributor. I'm not happy with how the wire connects to the distributor. I think those spade connectors could pull out or become loose.
I may re-do the whole thing at some point and use the stock remote stuff. Just didn't want to re-wire right now and spend a bunch of money and time.
DanWheeler
DanWheeler
Kirkland, WA
Does anyone know if a remote TFI distributor from say a 95 Mustang would have the same 3 wires that my current distributor has? If so, maybe I could buy a 95 stang distributor now just to have a better connection at the distributor but keep my TFI module and wiring as-is for now.,
DanWheeler
DanWheeler
Kirkland, WA
kinda answered my own question by looking at the wiring diagram on the previous page of this thread. Looks like they have a 6 pin connector. But I wonder if I could just use the 3 pins that I need for my setup?
Bronco_69
Monette Ar
No. Go get a oem ford distributor and connector end at the pull a part for $30. It took 30 minutes to solder the new wires in.
broncomitch
west jordan, utah
Wouldn't that keep the heat in? I'm guessing a lot of the heat that causes the problem is conducted from the motor to the distributor. Or maybe not, I don't know.
It shouldn't get very hot from the motor, if it is the ORing on the dizzy would be melted.
My guess is it would keep the hot air stuck under the hood out.
But I dunno ether, it's a pretty tried and true efi setup so it's odd it's even happening.
Before my efi I went through a ing box once a month and it was mounted in the cab, seems like the problem was I had it hard wired in and that would cause it to short out.. Or something stupid like that.
Hope this fixes your problem tho.
Jdgephar
When my TFI failed on my '89 F250, I left the failed one on the distributor, since the signal for the rotor position still worked. I then wired in a remote TFI with the stock heat sink from a late model Bronco. Worked like a champ.
KyleQ
When did you start having this issue? It seems like the amount of air the mechanical fan moves would keep this from happening? I've got a MSD Pro Billet and never had issues - looks like that is what that was too...
Kyle
DanWheeler
DanWheeler
Kirkland, WA
its been perfectly fine since I went EFI a couple years ago until beginning of August I'd say.
It very well could have been a loose connection or something else but I figure if Ford moved it off the distributor for a reason then I probably should too.
